[petsc-users] Save matrix to binary file on sub directory
Jed Brown jed at jedbrown.org
Thu Oct 2 12:04:49 CDT 2014
Robert Rezk <robertrezk at yahoo.ca> writes:
> I am using the pets viewer and I want to save binary file to sub directory.
> I tried to save file to the current directory and it work fine.
> when I try to use file name like this "./xyz_dir/file_name" it doesn't work.
What symptoms do you see?  Can you reproduce with an example?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141002/68932a85/attachment.pgp>
