[petsc-users] [petsc-dev] petsc git next branch *is* unwound!
Thu Oct 2 11:29:56 CDT 2014
  Too late. I likely screwed up the new next.
On Oct 2, 2014, at 11:26 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> balay at asterix /home/balay/petsc (master=)
> $ git co next
> Switched to branch 'next'
> Your branch is behind 'origin/next' by 1963 commits, and can be fast-forwarded.
>  (use "git pull" to update your local branch)
> balay at asterix /home/balay/petsc (next<)
> Did old next get remerged into new next? Should I rewind it again?
> Satish
> On Thu, 2 Oct 2014, Satish Balay wrote:
>> Sorry - perhaps the instructions should have been:
>> git checkout master
>> git branch -D next
>> git fetch
>> git checkout next
>> Satish
>> On Thu, 2 Oct 2014, Barry Smith wrote:
>>>  Why does it say "Already up-to-date.”  ? It’s like those things are already in next? Why isn’t it putting a bunch of stuff into next? Confusing
>>>   Barry
>>> ~/Src/petsc  next $ git checkout master
>>> Switched to branch 'master'
>>> Your branch is behind 'origin/master' by 3 commits, and can be fast-forwarded.
>>> ~/Src/petsc  master $ git branch -D next
>>> Deleted branch next (was 5fad734).
>>> ~/Src/petsc  master $ git checkout next
>>> Branch next set up to track remote branch next from origin.
>>> Switched to a new branch 'next'
>>> ~/Src/petsc  next $ git pull
>>> From bitbucket.org:petsc/petsc
>>> + 5fad734...6e2aac5 next       -> origin/next  (forced update)
>>> * [new branch]      next-oct-2014 -> origin/next-oct-2014
>>> Already up-to-date!
>>> Merge made by the 'recursive' strategy.
>>> ~/Src/petsc  next $ git merge barry/cleanup-blaslapack
>>> Already up-to-date.
>>> ~/Src/petsc  next $ git merge barry/remove-dreal
>>> Already up-to-date.
>>> ~/Src/petsc  next $ git merge barry/remove-sidl
>>> Already up-to-date.
>>> ~/Src/petsc  next $ git merge barry/reuse-hwloc
>>> Already up-to-date.
>>> ~/Src/petsc  next $ git push
>>> Counting objects: 1, done.
>>> Writing objects: 100% (1/1), 248 bytes | 0 bytes/s, done.
>>> Total 1 (delta 0), reused 0 (delta 0)
>>> To git at bitbucket.org:petsc/petsc.git
>>>   6e2aac5..8c34c3a  next -> next
>>> On Oct 2, 2014, at 8:16 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> petsc git users,
>>>> If you are using next branch from git repository for integration or
>>>> testing or working with it in some form - i.e if you have 'next'
>>>> listed by:
>>>> git branch
>>>> Please delete and recreate it. i.e:
>>>> git checkout master
>>>> git branch -D next
>>>> git checkout next
>>>> From my check - the following feature branches are currently in next
>>>> (not yet merged to master).
>>>> Feature branch owners, please remerge your feature branches into to
>>>> next - as you see fit.
>>>> $ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
>>>> origin/barry/cleanup-blaslapack
>>>> origin/barry/remove-dreal
>>>> origin/barry/remove-sidl
>>>> origin/barry/reuse-hwloc
>>>> origin/dmeiser/pullrequest-fix-cusp-bjacobi2
>>>> origin/dmeiser/pullrequest-remove-thrust-py
>>>> origin/jed/sr-driver4
>>>> origin/jed/vecghostgetvalues
>>>> origin/karlrupp/fix-viennacl-veccopy
>>>> origin/karpeev/fix-ksp-pcgasm
>>>> origin/knepley/feature-optcontrol-mg
>>>> origin/knepley/feature-plex-generator-args
>>>> origin/knepley/feature-plex-nasm
>>>> origin/knepley/fix-configure-petsc-dep
>>>> origin/knepley/fix-quadrature-order
>>>> origin/madams/sr-driver4
>>>> origin/maint
>>>> origin/mlange05/fix-gmsh-coordinates
>>>> origin/next
>>>> origin/paulmullowney/aijcusp-ellpack-fix
>>>> origin/prbrune/sf-examplefix
>>>> origin/prbrune/snes-ex19vtkoutput
>>>> origin/sarich/fix-tao-jbearing-bqpip
>>>> origin/shri/ts-dae-semi-explicit
>>>> origin/shri/ts-is-for-differential-variables
>>>> origin/shri/ts-powergrid
>>>> origin/stefano_zampini/matis-preallocation
>>>> origin/stefano_zampini/pcbddc-changeofbasis
>>>> origin/stefano_zampini/pcbddc_deluxe
>>>> origin/tisaac/feature-fe-geom-dim
>>>> origin/tisaac/plex-flexible-projection
>>>> [obviously remove maint, next from the above list]
>>>> The previous 'next' branch is currently available as 'next-oct-2014' -
>>>> if you need it for any checks/debugging.
>>>> Satish
