[petsc-users] examples of automatic differentiation with PETSc
Wed Oct 1 16:17:05 CDT 2014
  Thanks.
   Note that us removing the “simple minded” AD stuff from PETSc doesn’t mean we think AD is a bad idea. It can be an effective way to generate Jacobians.
   Barry
On Oct 1, 2014, at 4:09 PM, Gaetan Kenway <gaetank at gmail.com> wrote:
> HI Xiangdong
> We have use the Tapenade AD package to compute sparse matrix jacobians for CFD problems. We use the result from the AD to populate a PETSc sparse matrix and then use PETSc to solve the resulting linear system.
> Hope that helps.
> Gaetan
> On Wed, Oct 1, 2014 at 4:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Oct 1, 2014, at 3:16 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Xiangdong <epscodes at gmail.com> writes:
> >> Is there any reason that AD is not supported in PETSc? Is it because the
> >> ADIFOR/ADIC library itself?
> > Those libraries are not maintained and have license problems.  You're
> > welcome to use an AD tool yourself.  The support in PETSc was mostly
> > just making simple examples cleaner; it wasn't widely used in real
> > applications.
>    Wasn’t used at all in anything but trivial codes.
