[petsc-users] PETSC ERROR: Can only handle MPIU_REAL or MPIU_COMPLEX with ML preconditioner
Wed Oct 1 09:32:36 CDT 2014
  Recommend running under valgrind.  http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
On Oct 1, 2014, at 7:03 AM, Chris Richardson <chris at bpi.cam.ac.uk> wrote:
> On 01/10/2014 11:33, Matthew Knepley wrote:
>> On Wed, Oct 1, 2014 at 3:51 AM, Chris Richardson <chris at bpi.cam.ac.uk>
>> wrote:
>>> I have just run into this error after pulling the master branch of
>>> petsc, when using the ML preconditioner in FEniCS.
>>> It looks like a type error, but I guess FEniCS uses PETScInt, so
>>> should be safe?
>>> PETSC ERROR: Can only handle MPIU_REAL or MPIU_COMPLEX data types
>> We need to see the entire error (with the stack).
> OK, this kind of thing:-
> [1]PETSC ERROR: Can only handle MPIU_REAL or MPIU_COMPLEX data types
> ^C
> Program received signal SIGINT, Interrupt.
> 0x00007ffff64d9653 in epoll_wait () at ../sysdeps/unix/syscall-template.S:81
> 81      ../sysdeps/unix/syscall-template.S: No such file or directory.
> (gdb) up
> #1  0x00007ffff72c8591 in ?? () from /usr/lib/libmpi.so.1
> (gdb) up
> #2  0x00007ffff72ca787 in opal_event_base_loop () from /usr/lib/libmpi.so.1
> (gdb) up
> #3  0x00007ffff72eda3e in opal_progress () from /usr/lib/libmpi.so.1
> (gdb) up
> #4  0x00007fffb42884d5 in ?? ()
>   from /usr/lib/openmpi/lib/openmpi/mca_grpcomm_bad.so
> (gdb) up
> #5  0x00007ffff723d02a in ompi_mpi_finalize () from /usr/lib/libmpi.so.1
> (gdb) up
> #6  0x00007ffff7766b12 in dolfin::SubSystemsManager::finalize_mpi ()
>    at /opt/packages/src/dolfin/dolfin/common/SubSystemsManager.cpp:249
> 249           MPI_Finalize();
> (gdb) up
> #7  0x00007ffff7766cde in dolfin::SubSystemsManager::finalize ()
>    at /opt/packages/src/dolfin/dolfin/common/SubSystemsManager.cpp:219
> 219       finalize_mpi();
> (gdb) up
> #8  0x00007ffff641a149 in __run_exit_handlers (status=1,
>    listp=0x7ffff679d6c8 <__exit_funcs>,
>    run_list_atexit=run_list_atexit at entry=true) at exit.c:82
> 82      exit.c: No such file or directory.
> (gdb) up
> #9  0x00007ffff641a195 in __GI_exit (status=<optimised out>) at exit.c:104
> 104     in exit.c
> (gdb) up
> #10 0x00007ffff729cc00 in orte_ess_base_app_abort () from /usr/lib/libmpi.so.1
> (gdb) up
> #11 0x00007ffff729c2a9 in orte_errmgr_base_error_abort ()
> (gdb) up
> #12 0x00007ffff723bb69 in ompi_mpi_abort () from /usr/lib/libmpi.so.1
> (gdb) up
> #13 0x00007ffff37b9ee3 in PetscSum_Local (in=0x230f4520, out=0x7fffffffc650,
>    cnt=<optimised out>, datatype=0x7fffffffc428)
>    at /opt/packages/src/petsc/src/sys/objects/pinit.c:302
> 302         MPI_Abort(MPI_COMM_WORLD,1);
> (gdb) up
> #14 0x00007fffb10dd4dc in mca_coll_basic_scan_intra ()
>   from /usr/lib/openmpi/lib/openmpi/mca_coll_basic.so
> (gdb) up
> #15 0x00007fffb08c7e19 in mca_coll_sync_scan ()
>   from /usr/lib/openmpi/lib/openmpi/mca_coll_sync.so
> (gdb) up
> #16 0x00007ffff725835d in PMPI_Scan () from /usr/lib/libmpi.so.1
> (gdb) up
> #17 0x00007ffff413ec45 in MatWrapML_MPIAIJ (newmat=0x16a39228,
>    reuse=MAT_INITIAL_MATRIX, mlmat=0x7ed6090)
>    at /opt/packages/src/petsc/src/ksp/pc/impls/ml/ml.c:422
> 422         ierr = MPI_Scan(&m,&rstart,1,MPIU_INT,MPIU_SUM,mlmat->comm->USR_com);CHKERRQ(ierr);
> (gdb) list
> 417         ierr = MatSetSizes(A,m,n,PETSC_DECIDE,PETSC_DECIDE);CHKERRQ(ierr);
> 418         ierr = MatSetType(A,MATMPIAIJ);CHKERRQ(ierr);
> 419         /* keep track of block size for A matrices */
> 420         ierr = MatSetBlockSize (A,mlmat->num_PDEs);CHKERRQ(ierr);
> 421         ierr = PetscMalloc3(m,&nnzA,m,&nnzB,m,&nnz);CHKERRQ(ierr);
> 423         rstart -= m;
> 424
> 425         for (i=0; i<m; i++) {
> 426           row = gordering[i] - rstart;
> (gdb)
