[petsc-users] Scaling/Preconditioners for Poisson equation
Filippo Leonardi filippo.leonardi at sam.math.ethz.ch
Wed Oct 1 09:28:00 CDT 2014
On Wednesday 01 October 2014 07:23:03 Jed Brown wrote:
> Filippo Leonardi <filippo.leonardi at sam.math.ethz.ch> writes:
> > I am actually having hard time figuring out where I am spending my time.
> > Reading the report I am spending time on KSPSolve and PCApply (e+02).
> > Since
> > the number of those operations is well under control. I guess is some
> > communication that is the bottleneck.
> > The lines:
> > VecScatterBegin     4097 1.0 2.5168e+01 3.2 0.00e+00 0.0 2.9e+09 3.7e+01
> > 0.0e+00  3  0 87 39  0  10  0100100  0     0
> > VecScatterEnd       4097 1.0 1.7736e+02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> > 0.0e+00 25  0  0  0  0  88  0  0  0  0     0
> > are probably what is slowing down the solution.
> How large is your problem?
512^3 cells with 1 dof on 4096 processors
> > Also, times do not add up properly, especially in KSPSolve.
> Timings are inclusive, not exclusive.
> I don't know what is going on with the having the same event appear many
> times within the stage, but I remember fixing an issue that might have
> caused that years ago and I'd appreciate it if you would upgrade to the
> current version of PETSc.
I'll try if I can get some new version on the cluster I'm running. On my
laptop, using petsc 3.5, I get something like:
--- Event Stage 5: KspStage
VecMDot             1953 1.0 3.0402e-01 1.3 3.91e+07 1.0 0.0e+00 0.0e+00
2.0e+03  1  1  0  0  1   2  2  0  0  2   514
VecNorm             5445 1.0 3.6542e-01 1.1 4.46e+07 1.0 0.0e+00 0.0e+00
5.4e+03  1  1  0  0  3   3  2  0  0  4   488
VecScale            2465 1.0 1.8466e-02 1.1 1.01e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  2187
VecCopy             2979 1.0 3.5844e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              9134 1.0 2.7974e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY             2465 1.0 3.2354e-02 1.9 2.02e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  1  0  0  0  2497
VecAYPX             2466 1.0 2.7912e-02 1.5 1.01e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  1448
VecMAXPY            4418 1.0 4.7874e-02 1.1 9.42e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  1  0  0  0   0  4  0  0  0  7871
VecScatterBegin     6471 1.0 3.4048e-02 1.2 0.00e+00 0.0 4.8e+04 7.9e+02
0.0e+00  0  0  4  5  0   0  0 20 25  0     0
VecScatterEnd       6471 1.0 1.3429e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecNormalize        2466 1.0 2.5448e-01 1.0 3.03e+07 1.0 0.0e+00 0.0e+00
2.5e+03  1  0  0  0  1   2  1  0  0  2   476
MatMult             4419 1.0 3.9537e-01 1.2 1.63e+08 1.0 3.5e+04 1.0e+03
0.0e+00  1  2  3  5  0   3  7 15 24  0  1648
MatMultTranspose    1026 1.0 4.6899e-02 1.5 1.18e+07 1.0 1.2e+04 1.3e+02
0.0e+00  0  0  1  0  0   0  1  5  1  0  1008
MatLUFactorSym       513 1.0 7.8421e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  3  0  0  0  0   6  0  0  0  0     0
MatLUFactorNum       513 1.0 2.2127e+00 1.0 1.81e+09 1.0 0.0e+00 0.0e+00
0.0e+00  7 23  0  0  0  16 78  0  0  0  3269
MatConvert           513 1.0 4.4040e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
MatAssemblyBegin    4617 1.0 4.1133e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
4.1e+03  1  0  0  0  2   3  0  0  0  3     0
MatAssemblyEnd      4617 1.0 7.7171e-01 1.0 0.00e+00 0.0 4.9e+04 5.2e+01
1.6e+04  3  0  4  0  9   6  0 21  2 13     0
MatGetRowIJ          513 1.0 8.5605e-02 2.6 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetSubMatrice     513 1.0 3.5439e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
2.1e+03  1  0  0  0  1   3  0  0  0  2     0
MatGetOrdering       513 1.0 4.3043e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   3  0  0  0  0     0
MatPtAP             1026 1.0 3.1987e+00 1.0 1.29e+08 1.0 1.0e+05 4.1e+02
1.7e+04 11  2  8  5 10  24  6 44 28 14   162
MatPtAPSymbolic     1026 1.0 1.9393e+00 1.0 0.00e+00 0.0 6.8e+04 4.6e+02
7.2e+03  7  0  5  4  4  15  0 28 20  6     0
MatPtAPNumeric      1026 1.0 1.2644e+00 1.0 1.29e+08 1.0 3.7e+04 3.1e+02
1.0e+04  4  2  3  1  6  10  6 15  7  8   409
MatGetRedundant      513 1.0 4.0419e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatMPIConcateSeq     513 1.0 4.4424e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetLocalMat      1026 1.0 1.5555e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetBrAoCol       1026 1.0 1.7637e-01 1.3 0.00e+00 0.0 3.1e+04 8.0e+02
0.0e+00  1  0  2  3  0   1  0 13 16  0     0
MatGetSymTrans      2052 1.0 4.6286e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
KSPGMRESOrthog      1953 1.0 3.2750e-01 1.2 7.82e+07 1.0 0.0e+00 0.0e+00
2.0e+03  1  1  0  0  1   2  3  0  0  2   955
KSPSetUp            2565 1.0 8.8727e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
1.1e+04  3  0  0  0  6   7  0  0  0  9     0
Warning -- total time of even greater than time of entire stage -- something
is wrong with the timer
KSPSolve             513 1.0 2.7668e+01 1.0 7.65e+09 1.0 1.3e+06 5.7e+02
1.8e+05 94 98 95 90 99 209328528467143  1106
PCSetUp              513 1.0 1.0804e+01 1.0 1.95e+09 1.0 2.0e+05 5.8e+02
9.0e+04 36 25 15 15 51  81 84 85 76 73   722
PCApply             2466 1.0 1.4483e+01 1.0 5.32e+09 1.0 1.0e+06 5.5e+02
5.2e+04 49 68 77 71 30 109228428367 43  1469
MGSetup Level 0      513 1.0 4.3083e+00 1.0 1.81e+09 1.0 2.1e+04 1.3e+03
1.0e+04 14 23  2  3  6  32 78  9 18  8  1679
MGSetup Level 1      513 1.0 3.4038e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
3.1e+03  1  0  0  0  2   2  0  0  0  3     0
MGSetup Level 2      513 1.0 5.1557e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
3.1e+03  2  0  0  0  2   4  0  0  0  3     0
> How large is your problem size and how many processors are you running on?
> > PS: until now I was using outputs in VTK. I guess it is better to output
> > in
> > PEtsc binary?
> Yes.  You can use the binary-appended VTK viewer (please upgrade to
> current version of PETSc) or the PETSc binary viewer.
> > Is it better to output from PETSC_COMM_SELF (i.e. each processor
> > individually)?
> No, use collective IO.
Thanks.
Type: text/vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141001/682290f0/attachment.bin>
