[petsc-users] Problem with PETSc + HDF5 VecView
Jed Brown jed at jedbrown.org
Wed Nov 26 23:53:14 CST 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>> On Nov 26, 2014, at 3:35 PM, Håkon Strandenes <haakon at hakostra.net> wrote:
>> Is it really PETSc's taks to warn about this? PETSc should trust HDF5 to "just work" and HDF5 should actually print sensible warnings/error messages. Shouldn't it?
>    Yes, but if we produce a nice error message it makes everyone's
>    lives easier, including ours because we don't have to constantly
>    answer emails about the same problem discovered by a new person
>    over and over again. Hence we do this kind of thing a lot.
The only concern is that the user might not exceed that depth, so why
should they have to set an arbitrary and excessively big value?
MPI_REQUEST_MAX and MPI_COMM_MAX also look like candidates for needing
increases.
Whoever is responsible for this perversion should be fired.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141126/98bbf24f/attachment.pgp>
