[petsc-users] petsc-users Digest, Vol 71, Issue 59
Mon Nov 24 13:52:29 CST 2014
On Mon, 24 Nov 2014, Eric Bavier wrote:
> Evan,
> It looks like you're encountering a known bug in the cray release of
> petsc 3.5.1.0, which affects use of petsc with C++ compilers.  This bug
> will be fixed in cray-petsc/3.5.2.0.  In the meantime, you should be
> able to safely add the following two lines before #include <petscksp.h>
> #define PETSC_CXX_STATIC_INLINE static inline
> #define PETSC_CXX_RESTRICT __restrict__
Eric,
Glad to know the issue will be fixed in cray-petsc/3.5.2.0.
Thanks for the update.
Satish
