[petsc-users] AIJ asembly from AIJs
Sat Nov 22 17:17:26 CST 2014
On Sat, Nov 22, 2014 at 4:30 PM, Alp Kalpalp <alpkalpalp at gmail.com> wrote:
> Hi,
> I am a newby in PetSc but I could not find a solution to my problem. Let
> me describbe it to you.I have an SeqAIJ matrix on each processor. These
> substructures stiffness matrices should be assembled on a MPIAIJ and they
> have overlapping dofs (on boundaries). A is Eigen::SparseMatrix<double> and
> my code was as follows;
> ierr =
> MatCreateSeqAIJWithArrays(PETSC_COMM_SELF,m,n,A.outerIndexPtr(),A.innerIndexPtr(),A.valuePtr(),&subK);CHKERRQ(ierr);
> ierr =
> MatCreateMPIAIJSumSeqAIJ(PETSC_COMM_WORLD,subK,PETSC_DECIDE,PETSC_DECIDE,MAT_INITIAL_MATRIX,&K);CHKERRQ(ierr);
> Suppose I have 2 procs. first have 18x18 sparse mat, second hase 12x12
> sparse matrix. Assembled system should be 24x24 for this specific problem.
> Above code is wenting to infinite loops. debugger reports that there is a
> deadlock on the progman.
This function does not do this job:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateMPIAIJSumSeqAIJ.html
It clearly says "The dimensions of the sequential matrix in each processor
MUST be the same."
So, I searched for a workaroud and I found:
> MatCreateMPIAIJWithArrays and this function seems fails when the matrices
> has overlapping parts. So that it asembles 30x30 matrix'!!
> I check MatCreateMPIAIJ and it seems so costly to form d_nnz etc.
> Finally, I tried the MatCreate, MatSetValues procedure, however in here
> MatSetValues requires a coordinate list of values not CSR format arrays!!!
> So my question is how may I set and MPIAIJ from my (distributed)
> overlapping SeqAIJ matrices or preferebly using my CSR arrays directly?
1) I think the best option is to put your element matrices directly into
the MPIAIJ matrix, since each elemMat can be set with
    a single call to MatSetValues().
2) If that is too much reorganization, then I would
  a) Use MatCreateMPIAIJWithArrays() for the non-overlapping rows (remove
the ghost rows)
  b) Call MatSetValues() on each ghost row
3) If you cannot remove the overlapping rows, I would just call
MatSetValues() on each row. It is unlikely that
    the insertion process is a bottleneck in your computation (unless you
are not preallocating correctly)
     Matt
> Thanks in advance
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141122/1a53495b/attachment.html>
