[petsc-users] Indefinite PC
Sat Nov 22 11:00:58 CST 2014
   You could do -sys2_mg_levels_ksp_max_it 3   and/or -sys2_mg_coarse_pc_type redundant
   Or if you configured PETSc with a parallel direct solver like superlu_dist you could use -sys2_mg_coarse_pc_type  pc
          -sys2_mg_coarse_pc_mat_factor_solver_package superlu_dist
    Or you could keep the current PC gamg options and switch to -ksp_type bcgs
  Barry
> On Nov 21, 2014, at 11:05 PM, Anush Krishnan <k.anush at gmail.com> wrote:
> On 21 November 2014 18:23, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Nov 21, 2014, at 5:09 PM, Anush Krishnan <k.anush at gmail.com> wrote:
> > Hello petsc-users,
> > I've been running some CFD simulations, and I ran into one case where the system (which is a coupled system for pressure and body forces) did not converge and the reason was KSP_DIVERGED_INDEFINITE_PC. The options I'm using are -pc_gamg_agg_nsmooths 1 -pc_type gamg -pc_gamg_type agg with a conjugate gradient solver.
>    We've heard reports of this happening before. You should increase the number of smoothing steps for the multigrid or change to a "stronger" smoother.
>    What do you get with -ksp_view for exact solver you are using?
> I've attached a copy of the output with -ksp_view.
>    Are you using PETSc's SNES? TS? Or just KSP?
> Just KSP.
> > I saw in example ksp/pc/examples/tutorials/ex2.c that I should use the flag -pc_factor_shift_positive_definite to avoid this.
>    This flag is only for factorization based preconditioners not gamg so you should not use it.
> > I have a few questions regarding this:
> >       • What does it mean that the preconditioner is indefinite?
>     It means that the preconditioner generated by GAMG has both negative and positive eigenvalues. CG cannot handle this, CG  requires the preconditioner have all eigenvalues of the same sign.
> > What can cause this to happen? And what does the above flag do?
> >       • The error occurs midway through the simulation. Is there any reason why this might be the case? The left-hand side matrix does not change during the simulation.
>     Huh? If the matrix is not changing then the preconditioner should not be changing and hence the preconditioner should not be rebuilt and hence you should not see this message "midway through the simulation". Are you sure that the matrix is not changing??
> Yes, I'm sure that the matrix is not changing. Only the right hand side vector changes every time step.
> I have heard that CG sometimes converges even if the matrix is not positive definite - do you think that might be happening? Also, is there a way to check if a given matrix is positive definite using PETSc? And is it possible to generate an indefinite preconditioner from a matrix that is symmetric positive definite (I remember seeing a thread about this recently)?
> >       • Do both -pc_factor_shift_positive_definite and -pc_factor_shift_type POSITIVE_DEFINITE do the same thing?
>    Yes, they are from different versions of PETSc, but neither are for gamg.
>   Barry
> > Thank you,
> > Anush
> <ksp_view.txt>
