[petsc-users] Pipelined solvers PIPECG etc fail
Håkon Strandenes haakon at hakostra.net
Thu Nov 20 09:06:12 CST 2014
Ok:
If I run KSP ex 2 with parameters "-ksp_type pipecg -ksp_norm_type
natural", it works.
If I try *any* other norm, it fails, but with a different error message,
for example if I try "preconditioned":
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Scalar value must be same on all processes, argument # 2
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.2, unknown
[0]PETSC ERROR: ./ex2 on a arch-linux2-c-debug named hakostra-kontor by
hakostra Thu Nov 20 16:04:37 2014
[0]PETSC ERROR: Configure options --prefix=/opt/petsc/git-debug/install
--with-shared-libraries --download-hypre --with-64-bit-indices
--with-hdf5 --with-hdf5-dir=/opt/HDF5/1.8.13/install --with-debugging
--with-debugger=gdb
[0]PETSC ERROR: #1 VecAXPY() line 634 in
/opt/petsc/git-debug/source/src/vec/vec/interface/rvector.c
[0]PETSC ERROR: #2 KSPSolve_PIPECG() line 153 in
/opt/petsc/git-debug/source/src/ksp/ksp/impls/cg/pipecg/pipecg.c
[0]PETSC ERROR: #3 KSPSolve() line 459 in
/opt/petsc/git-debug/source/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #4 main() line 75 in /home/hakostra/Dropbox/KSP-ex2/ex2.c
Håkon
On 20. nov. 2014 15:49, Sascha Schnepp wrote:
> Hi,
> this is an error that occurs when calling ksp->converged and having
> ksp->normtype == KSP_NORM_NONE
> In pipecg.c the error occurs here:
> line99:  ierr       = (*ksp->converged)(ksp,0,dp,&ksp->reason,ksp->cnvP);CHKERRQ(ierr); /* test for convergence */
> It can be fixed (though there might be a nicer way) using this replacement code, wich explicitly calls KSPConvergendSkip for the respective norm:
>    if (ksp->normtype == KSP_NORM_NONE) {
>      ierr = KSPConvergedSkip (ksp,0,dp,&ksp->reason,ksp->cnvP);CHKERRQ(ierr);
>    } else {
> The issue could be related to this code in
> KSPCreate_PIPECG
>    ierr = KSPSetSupportedNorm(ksp,KSP_NORM_UNPRECONDITIONED,PC_LEFT,2);CHKERRQ(ierr);
>    ierr = KSPSetSupportedNorm(ksp,KSP_NORM_PRECONDITIONED,PC_LEFT,2);CHKERRQ(ierr);
>    ierr = KSPSetSupportedNorm(ksp,KSP_NORM_NATURAL,PC_LEFT,2);CHKERRQ(ierr);
>    ierr = KSPSetSupportedNorm(ksp,KSP_NORM_NONE,PC_LEFT,2);CHKERRQ(ierr);
> where all norms have the same priority.
> For the non-pipelined version of CG the unpreconditioned norm has a priority level of 3.
> The modifications are independent. Choosing different default priorities will still make line 99 fail if type NONE is chosen explicitly.
> Cheers,
> Sascha
> Begin forwarded message:
>> On Thu, Nov 20, 2014 at 4:05 AM, H?kon Strandenes <haakon at hakostra.net>
>> wrote:
>>> Hi,
>>> First: thanks to the list and Barry for solving my previous problem on
>>> loading vectors from HDF5 files. It works great!
>>> Now a second problem: I want to try the pipelined KSP solvers, PIPECG in
>>> particular. However, my program fails on the first KSPSolve() with the
>>> message below. The same happens if I try PIPECR.
>> These are very new, so there could be bugs lurking. It would help our
>> testing if this is
>> reproducuble on a standard example. Does this happen if you try to solve
>> KSP ex2
>> or SNES ex5 with PIPECG?
>>    Thanks,
>>      Matt
>>> I have tried this on three MPI implementations, on and two of them fully
>>> support MPI 3 (I have read http://www.mcs.anl.gov/petsc/
>>> documentation/faq.html#pipelined). I am using latest PETSc from Git repo.
>>> I have tried to turn off the preconditioner without any effect.
>>> The equation system is the result of a finite-volume discretization of a
>>> Poisson-like equation if that helps anything. A normal CG solver works like
>>> a charm, converging fast and effective.
>>> Are there any tricks to get this working? Anything special I have to set
>>> and/or define to get this solver running?
>>> Thanks in advance.
>>> Best regards,
>>> H?kon Strandenes
>>> Error message:
>>> [0]PETSC ERROR: Object is in wrong state
>>> [0]PETSC ERROR: Use KSPConvergedSkip() with KSPNormType of KSP_NORM_NONE
>>> [0]PETSC ERROR: madns on a arch-linux2-c-debug named hakostra-kontor by
>>> hakostra Thu Nov 20 11:04:28 2014
>>> --with-shared-libraries --download-hypre --with-64-bit-indices --with-hdf5
>>> --with-debugger=gdb
>>> [0]PETSC ERROR: #1 KSPConvergedDefault() line 710 in
>>> /opt/petsc/git-debug/source/src/ksp/ksp/interface/iterativ.c
>>> [0]PETSC ERROR: #2 KSPSolve_PIPECG() line 99 in
>>> [0]PETSC ERROR: #3 KSPSolve() line 459 in /opt/petsc/git-debug/source/
>>> [0]PETSC ERROR: #4 findPressure() line 53 in /opt/MaDNS/source/src/FVM2.cpp
