[petsc-users] PetscQuadratureCreate and PETSC_OBJECT_CLASSID
Dave May dave.mayhem23 at gmail.com
Tue Nov 18 15:51:44 CST 2014
Okay, thanks Matt. It now makes sense why it failed, but I don't understand
your logic.
The PetscQuadrature class is so small and doesn't depend on DM (at least
not in the definition of the structure described PetscQuadrature). Hence,
why should DMInitializePackage() have to be called at all?
I realize you how are you using PetscDT, but it should be available for
everyone - even if they don't ever create a DM.
Cheers,
  Dave
On 18 November 2014 22:46, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Nov 18, 2014 at 1:49 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
>> Hi,
>> I was trying to use some of DT functionality (in particular
>> PetscDTGaussTensorQuadrature()) in petsc 3.5.2 and I encountered this error:
> I did not anticipate someone calling that before anything by itself. You
> need a call to
> This is called by PetscQuadratureCreate().
>    Matt
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Invalid object classid 0
>> This could happen if you compile with PETSC_HAVE_DYNAMIC_LIBRARIES, but
>> link with static libraries.
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
>> [0]PETSC ERROR: ./dmdadg.app on a arch-darwin-c-mpi-debug-f2c named
>> nikkan.local by dmay Tue Nov 18 20:34:56 2014
>> [0]PETSC ERROR: Configure options --download-openmpi=yes
>> --with-debugging=yes --with-fc=0 --download-f2cblaslapck=yes
>> PETSC_ARCH=arch-darwin-c-mpi-debug-f2c
>> [0]PETSC ERROR: #1 PetscClassRegLogGetClass() line 290 in
>> /Users/dmay/software/petsc-3.5.2/src/sys/logging/utils/classlog.c
>> [0]PETSC ERROR: #2 PetscLogObjCreateDefault() line 317 in
>> [0]PETSC ERROR: #3 PetscQuadratureCreate() line 35 in
>> /Users/dmay/software/petsc-3.5.2/src/dm/dt/interface/dt.c
>> [0]PETSC ERROR: #4 PetscDTGaussTensorQuadrature() line 322 in
>> [0]PETSC ERROR: #5 DMDGSpace_ex4_quadrature() line 480 in dmdadg.c
>> [0]PETSC ERROR: #6 main() line 503 in dmdadg.c
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 1.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> Snooping around in the source tree, the only place where I can find
>> PetscHeaderCreate being passed PETSC_OBJECT_CLASSID is within
>> src/dm/dt/interface/dt.c in the function PetscQuadratureCreate().
>> Is this is a bug or is my petsc build broken??
>> I'm sure I am linking against a dynamic library (or whatever you want to
>> call a dylib on OSX)
>> dmay at nikkan:~/codes/dgspace$ otool -L dmdadg.app
>> dmdadg.app:
>> /Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libpetsc.3.5.dylib
>> (compatibility version 3.5.0, current version 3.5.2)*
>> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
>> (compatibility version 1.0.0, current version 1.0.0)
>> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
>>     /opt/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current
>> version 10.0.0)
>>     /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
>> version 1197.1.1)
>>     /usr/lib/libssl.0.9.8.dylib (compatibility version 0.9.8, current
>> version 50.0.0)
>>     /usr/lib/libcrypto.0.9.8.dylib (compatibility version 0.9.8, current
>> version 50.0.0)
>> /Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libmpi_cxx.1.dylib
>> (compatibility version 3.0.0, current version 3.3.0)
>>     /usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version
>> 120.0.0)
>> /Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libmpi.1.dylib
>> (compatibility version 7.0.0, current version 7.0.0)
>> Cheers,
>>   Dave
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141118/572492ef/attachment.html>
