[petsc-users] PetscQuadratureCreate and PETSC_OBJECT_CLASSID
Dave May dave.mayhem23 at gmail.com
Tue Nov 18 13:49:25 CST 2014
I was trying to use some of DT functionality (in particular
PetscDTGaussTensorQuadrature()) in petsc 3.5.2 and I encountered this error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Invalid object classid 0
This could happen if you compile with PETSC_HAVE_DYNAMIC_LIBRARIES, but
link with static libraries.
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.2, Sep, 08, 2014
[0]PETSC ERROR: ./dmdadg.app on a arch-darwin-c-mpi-debug-f2c named
nikkan.local by dmay Tue Nov 18 20:34:56 2014
[0]PETSC ERROR: Configure options --download-openmpi=yes
--with-debugging=yes --with-fc=0 --download-f2cblaslapck=yes
PETSC_ARCH=arch-darwin-c-mpi-debug-f2c
[0]PETSC ERROR: #1 PetscClassRegLogGetClass() line 290 in
/Users/dmay/software/petsc-3.5.2/src/sys/logging/utils/classlog.c
[0]PETSC ERROR: #2 PetscLogObjCreateDefault() line 317 in
[0]PETSC ERROR: #3 PetscQuadratureCreate() line 35 in
/Users/dmay/software/petsc-3.5.2/src/dm/dt/interface/dt.c
[0]PETSC ERROR: #4 PetscDTGaussTensorQuadrature() line 322 in
[0]PETSC ERROR: #5 DMDGSpace_ex4_quadrature() line 480 in dmdadg.c
[0]PETSC ERROR: #6 main() line 503 in dmdadg.c
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Snooping around in the source tree, the only place where I can find
PetscHeaderCreate being passed PETSC_OBJECT_CLASSID is within
src/dm/dt/interface/dt.c in the function PetscQuadratureCreate().
Is this is a bug or is my petsc build broken??
I'm sure I am linking against a dynamic library (or whatever you want to
call a dylib on OSX)
dmay at nikkan:~/codes/dgspace$ otool -L dmdadg.app
dmdadg.app:
/Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libpetsc.3.5.dylib
(compatibility version 3.5.0, current version 3.5.2)*
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
(compatibility version 1.0.0, current version 1.0.0)
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    /opt/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current
version 10.0.0)
    /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
version 1197.1.1)
    /usr/lib/libssl.0.9.8.dylib (compatibility version 0.9.8, current
version 50.0.0)
    /usr/lib/libcrypto.0.9.8.dylib (compatibility version 0.9.8, current
version 50.0.0)
/Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libmpi_cxx.1.dylib
(compatibility version 3.0.0, current version 3.3.0)
    /usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version
120.0.0)
/Users/dmay/software/petsc-3.5.2/arch-darwin-c-mpi-debug-f2c/lib/libmpi.1.dylib
(compatibility version 7.0.0, current version 7.0.0)
Cheers,
  Dave
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141118/0bad3b12/attachment.html>
