[petsc-users] PetscFunctionBegin, -malloc_dump and C++ classes with PETSc objects
Tue Nov 18 11:32:34 CST 2014
> On Nov 18, 2014, at 11:19 AM, Miguel Angel Salazar de Troya <salazardetroya at gmail.com> wrote:
> Hi
> I'm implementing a problem using the TS. Most of my functions are methods inside of a class, except for the callbacks (to form the RHS and the TS monitor), which are outside of the class, although in the same .C file where the class methods are implemented. For these callbacks I followed the network example:
> https://bitbucket.org/petsc/petsc/src/a614f7369d93d476173b8fc6bf2463276dcbdb3a/src/snes/examples/tutorials/network/pflow/pf.c?at=master
> Therefore, the callbacks have the PetscFunctionBegin at the beginning and PetscFunctionReturn(0) at the end. My problems come when I run the program with -malloc_dump and I get a lot of unfreed memory. Inspecting the output I see that the line of my code where the memory is allocated corresponds with the line when PetscFunctionBegin is called.
  This is normal. We cannot register the exact line the memory allocated, only the location of the PETScFunctionBegin;
> Later in the file, I see that the function DMGetLocalVector() is called within a petsc internal routine (at the file dmget.c). I also call this routine in my callback methods few lines after PetscFunctionBegin. The procedure that I follow to use the local vectors is as the one in the network example. For vectors that I want to modify this is:
>  ierr = DMGetLocalVector(networkdm,&localX);CHKERRQ(ierr);
>  ierr = DMGlobalToLocalBegin(networkdm,X,INSERT_VALUES,localX);CHKERRQ(ierr);
>  ierr = DMGlobalToLocalEnd(networkdm,X,INSERT_VALUES,localX);CHKERRQ(ierr);
>  ierr = VecGetArray(localX,&xarr);CHKERRQ(ierr);
> Modify values in xarr
>  ierr = VecRestoreArray(localX,&xarr);CHKERRQ(ierr);
>  ierr = DMLocalToGlobalBegin(networkdm,localX,INSERT_VALUES,X);CHKERRQ(ierr);
>  ierr = DMLocalToGlobalEnd(networkdm,localX,INSERT_VALUES,X);CHKERRQ(ierr);
>  ierr = DMRestoreLocalVector(networkdm,&localX);CHKERRQ(ierr);
> One last thing that I think it might be a issue here is how I destroy the petsc objects. I create the petsc objects within a class. For instance, the class has a petsc vector that later passes to the TS object to get the solution. To destroy the petsc objects, I use the class destructor, where at the end I call PetscFinalize() Inside the class I pass the callbacks to the TS routines that need them (e.g. TSSetRHSFunction() ) I can compile the code and run it, but many memory allocations are not freed. What can be the issue here? Do you know of an example using C++ classes to implement PETSc methods? Thanks in advance.
   Do you call the class destructor yourself explicitly before the PetscFinalize()? You need to, otherwise the class may not be destroyed until after PetscFinalize() and hence the PETSc objects won't be freed when you call PetscFinalize().
   You also need to make sure that you destroy ALL PETSc objects, if you miss even one PETSc object, since the objects have references to each other it may be that many PETSc objects do not get freed and hence -malloc_dump shows many objects still alive.
  Barry
> Miguel
> Graduate Research Assistant
> Department of Mechanical Science and Engineering
> University of Illinois at Urbana-Champaign
> (217) 550-2360
> salaza11 at illinois.edu
