[petsc-users] Nullspaces for schur complement PCs
Jed Brown jed at jedbrown.org
Wed Nov 12 19:12:13 CST 2014
Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> writes:
> So is the problem that the nullspace belongs to the appropriate
> operator, but at the point you tell the solver, you don't necessarily
> have all the operators to hand?  Moreover, depending on the PC choice,
> the nullspaces of the operator blocks may or may not be relevant?
Given the system [A B; C D], the null space of D has nothing to do with
the null space of S = D - C A^{-1} B.  In some important cases, D is the
zero matrix, for example.  Using MatSetNullSpace to set a null space on
D (even if you have it in hand) is lying and may cause the wrong thing
to happen if you use a different solver configuration (e.g., a
relaxation split).
Attaching a null space to an IS is damn perverse because an index set is
a bag of integers and you're labeling it with information about a Mat
that is the result of some other algorithm using lots more information
than just the IS (and done in a non-unique way).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141113/818ff46e/attachment-0001.pgp>
