[petsc-users] passing solver options in fieldsplit
Luc Berger-Vergiat lb2653 at columbia.edu
Wed Nov 12 16:24:26 CST 2014
the option -help was quite useful and I got things to work fine with
icntl_14 50.
Best,
Luc
On 11/11/2014 11:07 AM, Hong wrote:
> Luc:
> Run your code with option '-help |grep mumps', then you'll see what
> prefix should be used in your case with the mumps option
> '-mat_mumps_icntl_14 30'.
> You may try even larger icntl_14.
> Hong
>     Hi, I am using Petsc to solver a multiphysics problem and I have
>     the following issue.
>     I partition my problem by declaring two fields:
>         -ksp_type gmres -pc_type fieldsplit -pc_fieldsplit_type schur
>         -pc_fieldsplit_schur_factorization_type full
>         -pc_fieldsplit_schur_precondition selfp
>         -pc_fieldsplit_0_fields 2,3 -pc_fieldsplit_1_fields 0,1
>     I want to solve the matrix representing field 0 with mumps so I
>     pass the following following arguments:
>         -fieldsplit_0_ksp_type preonly -fieldsplit_0_pc_type lu
>         -fieldsplit_0_pc_factor_mat_solver_package mumps
>     When I do this I get an error from mumps: INFO(1)=-9,
>     INFO(2)=12532. This means that mumps main internal real workarray
>     is too small and 12532 are missing. To try to mitigate this I need
>     to want to set mumps ICNTL(14)=30 (by default it is 20).
>     Reading Petsc documentation I find that I have to pass the
>     following argument to my program:
>     which does work fine when I work without fieldsplit but not when I
>     use field split.
>     I also tried:
>         -fieldsplit_0_mat_mumps_icntl_14 30
>     which does not work any better.
>     Any idea how I should pass the icntl_14 information to mumps in
>     this case?
>     Best,
>     Luc
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141112/d9cb64b1/attachment.html>
