[petsc-users] Nonconforming object sizes ERROR
Brian Yang brianyang1106 at gmail.com
Wed Nov 12 14:46:55 CST 2014
Thank you for the prompt response. I checked and my usage of KSPSolve is
correct.
Besides, the assertion line is:
if (*mat->rmap->N* != *y->map->N*)
SETERRQ2(PETSC_COMM_SELF,PETSC_ERR_ARG_SIZ,"Mat mat,Vec y: global dim %D
%D",mat->rmap->N,y->map->N);
On Wed, Nov 12, 2014 at 2:29 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   The calling sequence for KSPSolve is KSPSolve(KSP ksp,Vec b,Vec x),
> perhaps you have the b and the x backwards in your call?
>   Barry
> > On Nov 12, 2014, at 2:23 PM, Brian Yang <brianyang1106 at gmail.com> wrote:
> > Hi,
> > I am solving an over-determined linear system Ax=b and b=0.
> > A size: 296856 x 14430
> > x (non-zero guess): 14430
> > b (zero): 296856
> > All of them are using seq mode to create, so one node will solve this.
> However I got this error:
> > [0]PETSC ERROR: Nonconforming object sizes!
> > [0]PETSC ERROR: Mat mat,Vec y: global dim 296856 14430!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: MatMult() line 2171 in src/mat/interface/matrix.c
> > [0]PETSC ERROR: KSP_MatMult() line 204 in
> src/ksp/ksp/impls/cg//datadb/raafat/src/petsc-3.4.3/include/petsc-private/kspimpl.h
> > [0]PETSC ERROR: KSPSolve_CG() line 132 in src/ksp/ksp/impls/cg/cg.c
> > [0]PETSC ERROR: KSPSolve() line 441 in src/ksp/ksp/interface/itfunc.c
> > Any restrictions here or I misunderstood something? Thanks!
> > Brian Yang
> > U of Houston
Brian Yang
U of Houston
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141112/137eb40a/attachment.html>
