[petsc-users] Nullspaces for schur complement PCs
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Mon Nov 10 17:34:38 CST 2014
On 10 Nov 2014, at 21:48, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Nov 7, 2014 at 11:04 AM, Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk>wrote:
> Hi petsc-dev,
> I'm solving a pure Neumann mixed Poisson-like problem, preconditioning with a schur complement.  The pressure space has a nullspace of the constant functions and so I attach the appropriate nullspace to the krylov solver, and compose the constant nullspace with the IS defining the pressure space.  My RHS is consistent.
> That is supposed to work, and I think it does in my tests. The code is here
>   https://bitbucket.org/petsc/petsc/src/1f0d623c8336219eb98f7ded6f95c151ca603fe7/src/ksp/pc/impls/fieldsplit/fieldsplit.c?at=master#cl-562
That code attaches the nullspace attached to the IS to jac->pmat if appropriate.  However, if I'm using -pc_fieldsplit_schur_precondition selfp then the schur complement is preconditioned with jac->schurp (rather than jac->pmat[1]) which is not setup until here https://bitbucket.org/petsc/petsc/src/1f0d623c8336219eb98f7ded6f95c151ca603fe7/src/ksp/pc/impls/fieldsplit/fieldsplit.c?at=master#cl-656
at which point the nullspace is not attached, no?
Cheers,
Lawrence
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141110/ee26d9e8/attachment.pgp>
