[petsc-users] Multiple solves with PCMG fail
Filippo Leonardi filippo.leonardi at sam.math.ethz.ch
Mon Nov 10 08:46:56 CST 2014
Switched branch and now it works. No error and the solution is correct. I
guess i not that more inefficient since the times when the rhs is zero is not
that often, otherwise you wouldn't solve the system that way.
I'm stupid: somehow I was in master and didn't notice that. Sorry for the
confusion.
On Monday 10 November 2014 09.26:45 you wrote:
> It does not look like you are in fact using the branch with this fix.  The
> branch code looks like:
Name: Filippo Leonardi.vcf
Type: text/vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141110/dd20e2a4/attachment.bin>
