[petsc-users] KrylovSchur solver diverges when setting EPS_GHEP
Jose E. Roman jroman at dsic.upv.es
Fri Nov 7 09:03:31 CST 2014
El 07/11/2014, a las 15:45, Denis Davydov escribió:
>> What do you mean by 'breaks convergence'? Are you sure your matrices are symmetric?
>> Jose
> I shall clarify that the calculated by EPSComputeResidualNorm residual norm
> is bigger than the required tolerance, set by EPSSetTolerances.
> In light of your latest answer about B-norms,
> supposedly this is a wrong approach.
> Sorry for being un-precise initially.
> Regards,
> Denis.
Yes, EPSComputeResidualNorm uses the 2-norm.
Maybe it would be better if the stopping criterion in symmetric problems would be more similar to the non-symmetric case. I will think about it. It would be good if you could send me sample matrices (to my personal email).
Jose
