[petsc-users] KrylovSchur solver diverges when setting EPS_GHEP
Jose E. Roman jroman at dsic.upv.es
Fri Nov 7 08:14:56 CST 2014
El 07/11/2014, a las 15:10, Denis Davydov escribió:
> Dear all,
> I was trying to set the problem type to EPS_GHEP as
> the matrices in the considered generalised eigenvalue problem are real and symmetric.
> However, this breaks the solver's convergence as compared to the default, non-symmetric case.
> The residual is quite small (~1e-9). I am puzzled why this happens.
> The output with -eps_view -esp_monitor_all flags is below.
> Thank you in advance for any advices on the issue.
> Kind regards,
> Denis
What do you mean by 'breaks convergence'? Are you sure your matrices are symmetric?
Jose
