[petsc-users] Speed up KSPSolve of dense matrix
Florian Lindner mailinglists at xgm.de
Fri Nov 7 07:03:28 CST 2014
Hey,
I've modified my code that it counts the total number of non-zeros (trivial to put in the preallocation code) and decides upon that wheather to create a MATSBAIJ or MATDENSE matrix.
Using sparse matrices (for one that is really dense) I've made good experiences with -pc_factor_shift_type NONZERO  -pc_type cholesky -ksp_type preonly. But when I use that on a MATDENSE I again get a a Zero pivot in LU factorization though using pc_factor_shift_type.
I suspect that is related to the MATDENSE matrix intended to be symmetric, but actually is not. I have MAT_SYMMETRY_ETERNAL set but when I view the matrix only the upper right triangular is set, how I did in my matrix assembly algorithm. Do the algorithm treat the matrix as symmetric when MAT_SYMMETRY_ETERNAL is set or is just a little hint? Any way to actually set a MATDENSE matrix to be symmetric or do I need to copy the entries to the lower triangular?
Florian
Am Mittwoch, 5. November 2014, 08:36:26 schrieb Barry Smith:
>   So you have a dense, very ill-conditioned matrix. Seems to me you should just be using the dense LU/Cholesky factorization unless you know how to preconditioner these types of matrices.  http://scicomp.stackexchange.com/questions/7561/do-rbf-kernel-matrices-tend-to-be-ill-conditioned
> You can’t expect to take monstrously ill-conditioned matrices and expect to use iterative methods unless you really really really understand the source and and control of the ill-conditioning.
>  What is your end goal in trying to use iterative methods?
>   Barry
> > On Nov 5, 2014, at 3:41 AM, Florian Lindner <mailinglists at xgm.de> wrote:
> > Am Dienstag, 4. November 2014, 10:08:27 schrieb Barry Smith:
> >>   There are a lot of questions here.
> > Yes, thanks for replying!
> >>> On Nov 4, 2014, at 328 AM, Florian Lindner <mailinglists at xgm.de> wrote:
> >>> Hello,
> >>> I have a fulll matrix of size e.g. 603x603 of which I'm very disappointed with the runtime, compared to a naive LU / forward / backward solution. My petsc solution takes about 14s, while the old one takes just 0.5s. (when you're looking at sparse matrices the figures are almost inversed). I try to investigate what's the problem.
> >>   For small problems like this direct dense LU could easily be faster than iterative schemes. Especially if you have many right hand sides with the same matrix since the factorization only needs to be done one.
> >>> Most of the time is spent in the KSPSolve.
> >>> Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
> >>>                  Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> >>> --- Event Stage 0: Main Stage
> >>> MatMult            10334 1.0 6.3801e+00 1.0 7.51e+09 1.0 0.0e+00 0.0e+00 0.0e+00 45 49  0  0  0  45 49  0  0  0  1177
> >>> MatSolve           10334 1.0 6.9187e+00 1.0 7.51e+09 1.0 0.0e+00 0.0e+00 0.0e+00 49 49  0  0  0  49 49  0  0  0  1085
> >>   If this is for a single solver for a 603 by 603 matrix then this is absurd.  10000 plus iterations
> > But that's the output I got. When I run with -info I get a lot of messages:
> > [0] PCSetUp(): Leaving PC with identical preconditioner since operator is unchanged
> > though doing just on KSPSolve / KSPSetOperators. Is that ok?
> >>> MatCholFctrNum         1 1.0 1.8968e-01 1.0 6.03e+02 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> >>> KSPGMRESOrthog     10000 1.0 2.1417e-01 1.0 3.73e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  2  0  0  0   2  2  0  0  0  1744
> >>> KSPSolve               1 1.0 1.3763e+01 1.0 1.54e+10 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1120
> >>> Prealloc Matrix C       1 1.0 5.7458e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> >>> Filling Matrix C       1 1.0 6.7984e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> >>> VecMDot            10000 1.0 8.8615e-02 1.0 1.87e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  2106
> >>> VecMAXPY           10334 1.0 1.2585e-01 1.0 1.99e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1580
> >>> Prealloc Matrix A       1 1.0 1.1071e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> >>> Filling Matrix A       1 1.0 1.2574e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> >>> PCSetUp                1 1.0 1.9073e-01 1.0 6.03e+02 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> >>> PCApply            10334 1.0 6.9233e+00 1.0 7.51e+09 1.0 0.0e+00 0.0e+00 0.0e+00 49 49  0  0  0  49 49  0  0  0  1085
> >>> Removed all events with global %T == 0, but my own ones.
> >>> Matrix type is sequential MATSBAIJ on PETSC_COMM_SELF.
> >>> KSP is initalized once:
> >>> KSPSetOperators(_solver, _matrixC.matrix, _matrixC.matrix);
> >>> KSPSetTolerances(_solver, _solverRtol, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
> >>> KSPSetFromOptions(_solver);
> >>> KSPSolve:
> >>> ierr = KSPSolve(_solver, in.vector, p.vector); CHKERRV(ierr)
> >>> KSPSolve may be executed multiple times with the same SetOperators acording to dimensionality of the data. Here it's just one.
> >>> -ksp_view says:
> >>> KSP Object: 1 MPI processes
> >>> type: gmres
> >>>   GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> >>>   GMRES: happy breakdown tolerance 1e-30
> >>> maximum iterations=10000, initial guess is zero
> >>> tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
> >>> left preconditioning
> >>> using PRECONDITIONED norm type for convergence test
> >>> PC Object: 1 MPI processes
> >>> type: icc
> >>>   0 levels of fill
> >>>   tolerance for zero pivot 2.22045e-14
> >>>   using Manteuffel shift [POSITIVE_DEFINITE]
> >>>   matrix ordering: natural
> >>>   factor fill ratio given 1, needed 1
> >>>     Factored matrix follows:
> >>>       Mat Object:         1 MPI processes
> >>>         type: seqsbaij
> >>>         rows=603, cols=603
> >>>         package used to perform factorization: petsc
> >>>         total: nonzeros=182103, allocated nonzeros=182103
> >>>         total number of mallocs used during MatSetValues calls =0
> >>>             block size is 1
> >>> linear system matrix = precond matrix:
> >>> Mat Object:  C   1 MPI processes
> >>>   type: seqsbaij
> >>>   rows=603, cols=603
> >>>       block size is 1
> >>> I've tried to use a direct solver like suggested on pp 72, but:
> >>> ./petBench 600 1 -ksp_type preonly -pc_type lu
> >>  You cannot use LU with SBAIJ format. Only Cholesky. So use -pc_type cholesky
> > I tried that too, it gives me an error message:
> > % ./petBench 100 1 -pc_type cholesky
> > Mesh of size: 100
> > Do mappings: 1
> > KSP Init
> > Do KSPSolve consistent
> > [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [0]PETSC ERROR: Zero pivot in LU factorization: http://www.mcs.anl.gov/petsc/documentation/faq.html#ZeroPivot
> > [0]PETSC ERROR: Zero pivot row 0 value 0 tolerance 2.22045e-14
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.5.2, unknown
> > [0]PETSC ERROR: ./petBench on a arch-linux2-c-debug named helium by lindnefn Wed Nov  5 10:22:07 2014
> > [0]PETSC ERROR: Configure options --with-debugging=1
> > [0]PETSC ERROR: #1 MatPivotCheck_none() line 622 in /data2/scratch/lindner/petsc/include/petsc-private/matimpl.h
> > [0]PETSC ERROR: #2 MatPivotCheck() line 641 in /data2/scratch/lindner/petsc/include/petsc-private/matimpl.h
> > [0]PETSC ERROR: #3 MatCholeskyFactorNumeric_SeqSBAIJ_1_NaturalOrdering() line 1435 in /data2/scratch/lindner/petsc/src/mat/impls/sbaij/seq/sbaijfact.c
> > [0]PETSC ERROR: #4 MatCholeskyFactorNumeric() line 3063 in /data2/scratch/lindner/petsc/src/mat/interface/matrix.c
> > [0]PETSC ERROR: #5 PCSetUp_Cholesky() line 150 in /data2/scratch/lindner/petsc/src/ksp/pc/impls/factor/cholesky/cholesky.c
> > [0]PETSC ERROR: #6 PCSetUp() line 902 in /data2/scratch/lindner/petsc/src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: #7 KSPSetUp() line 305 in /data2/scratch/lindner/petsc/src/ksp/ksp/interface/itfunc.c
> > [0]PETSC ERROR: #8 KSPSolve() line 417 in /data2/scratch/lindner/petsc/src/ksp/ksp/interface/itfunc.c
> > [0]PETSC ERROR: #9 map() line 401 in /data2/scratch/lindner/precice/src/mapping/PetRadialBasisFctMapping.hpp
> > FAQ says I likely have an error in my matrix generation when it occurs in the zeroth row. But for RBF the main diagonal is always BasisFunction( | x_n - x_n | ). Since I test with ThinPlateSplines as basis function here it's TPS(0) == 0.
> >>> Mesh of size: 600
> >>> Do mappings: 1
> >>> [0]PETSC ERROR: No support for this operation for this object type
> >>> [0]PETSC ERROR: Factor type not supported
> >>> [0]PETSC ERROR: ./petBench on a arch-linux2-c-opt named helium by lindnefn Tue Nov  4 10:19:28 2014
> >>> [0]PETSC ERROR: Configure options --with-debugging=0
> >>> [0]PETSC ERROR: #1 MatGetFactor_seqsbaij_petsc() line 1833 in /data2/scratch/lindner/petsc/src/mat/impls/sbaij/seq/sbaij.c
> >>> [0]PETSC ERROR: #2 MatGetFactor() line 3963 in /data2/scratch/lindner/petsc/src/mat/interface/matrix.c
> >>> [0]PETSC ERROR: #3 PCSetUp_LU() line 125 in /data2/scratch/lindner/petsc/src/ksp/pc/impls/factor/lu/lu.c
> >>> [0]PETSC ERROR: #4 PCSetUp() line 902 in /data2/scratch/lindner/petsc/src/ksp/pc/interface/precon.c
> >>> [0]PETSC ERROR: #5 KSPSetUp() line 305 in /data2/scratch/lindner/petsc/src/ksp/ksp/interface/itfunc.c
> >>> [0]PETSC ERROR: #6 KSPSolve() line 417 in /data2/scratch/lindner/petsc/src/ksp/ksp/interface/itfunc.c
> >>> [0]PETSC ERROR: #7 map() line 391 in /data2/scratch/lindner/precice/src/mapping/PetRadialBasisFctMapping.hpp
> > Thanks,
> > Florian
