[petsc-users] Nullspaces for schur complement PCs
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Fri Nov 7 05:04:59 CST 2014
Hi petsc-dev,
I'm solving a pure Neumann mixed Poisson-like problem, preconditioning with a schur complement.  The pressure space has a nullspace of the constant functions and so I attach the appropriate nullspace to the krylov solver, and compose the constant nullspace with the IS defining the pressure space.  My RHS is consistent.
When I precondition with:
-pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_fact_type full \
-pc_fieldsplit_schur_precondition selfp
I notice that the nullspace is not transferred over to the preconditioning matrix for S.  Is this a deliberate choice?
ksp_view output below, note that the schurcomplement mat has an attached nullspace, but the generated pmat does not.
Cheers,
Lawrence
KSP Object: 1 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=30, initial guess is zero
  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses (the lumped) A00's diagonal's inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       1 MPI processes
        type: gmres
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      PC Object:      (fieldsplit_0_)       1 MPI processes
        type: ilu
          ILU: out-of-place factorization
          0 levels of fill
          tolerance for zero pivot 2.22045e-14
          matrix ordering: natural
          factor fill ratio given 1, needed 1
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=72, cols=72
                package used to perform factorization: petsc
                total: nonzeros=1080, allocated nonzeros=1080
                total number of mallocs used during MatSetValues calls =0
                  using I-node routines: found 23 nodes, limit used is 5
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_0_)         1 MPI processes
          type: seqaij
          rows=72, cols=72
          total: nonzeros=1080, allocated nonzeros=0
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_1_)       1 MPI processes
        type: gmres
      PC Object:      (fieldsplit_1_)       1 MPI processes
        type: ilu
          0 levels of fill
                type: seqaij
                rows=24, cols=24
                total: nonzeros=216, allocated nonzeros=216
                  using I-node routines: found 8 nodes, limit used is 5
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (fieldsplit_1_)         1 MPI processes
          type: schurcomplement
          rows=24, cols=24
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
                rows=24, cols=24
                total: nonzeros=72, allocated nonzeros=0
            A10
                type: seqaij
                rows=24, cols=72
                total: nonzeros=288, allocated nonzeros=0
            KSP of A00
                type: gmres
                type: ilu
                  0 levels of fill
                        type: seqaij
                        rows=72, cols=72
                  type: seqaij
                  rows=72, cols=72
            A01
                type: seqaij
                rows=72, cols=24
          type: seqaij
          rows=24, cols=24
    type: nest
    rows=96, cols=96
      Matrix object:
        type=nest, rows=2, cols=2
        MatNest structure:
        (0,0) : prefix="fieldsplit_0_", type=seqaij, rows=72, cols=72
        (0,1) : type=seqaij, rows=72, cols=24
        (1,0) : type=seqaij, rows=24, cols=72
        (1,1) : prefix="fieldsplit_1_", type=seqaij, rows=24, cols=24
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141107/d363d75e/attachment.pgp>
