[petsc-users] Error message of nnz cannot be greater than block row length from MatSetValues()
Evan Um evanum at gmail.com
Thu Nov 6 13:54:39 CST 2014
Dear PETSC users,
I hope that I can have a comment about errors I got during sparse symmetric
matrix construction. In this example, I used three processes. The size of a
test matrix is 52105-by-52105. The length of array d_nnz and o_nnz is 17461
at rank 0, 17111 at rank 1 and 17535 at rank 2. The two arrays exactly
describe nnz of the diagonal and off-diagonal part. At rank 0, I tried
to add 148767 element for the diagonal part and 5821 for the off-diagonal
part. At rank 1, I tried to add 135826 and 19541 for the diagonal and
off-diagonal parts, respectively. At rank 2, I tried to add 138155 and 0
for the diagonal and off-diagonal parts. Rank 0 has matrix rows from 0 to
17460; rank 1 from 17460 to 34570 and rank 2 from 34570 to 52104.
During the run, I got an error message: nnz cannot be greater than block
row length: local row 17124 value 38762560 rowlength 17368. My d_nnz and
o_nnz arrays never have a value such as 38762560. Could anyone help me
decode this error message? In advance, I appreciate your help.
Evan
// CODE
MatCreate(PETSC_COMM_WORLD,&B);
MatSetSizes(B,PETSC_DECIDE,PETSC_DECIDE,ngedges_internal,ngedges_internal);
MatSetType(B,MATSBAIJ);
MatMPISBAIJSetPreallocation(B,1,0,d_nnz,0,o_nnz);
delete [] d_nnz;
delete [] o_nnz;
MatSetValues(B, nentries_mat_b_partitioned, mat_b_i_partitioned,
nentries_mat_b_partitioned, mat_b_j_partitioned, mat_b_val_partitioned,
ADD_VALUES);
delete [] mat_b_i_partitioned;
delete [] mat_b_j_partitioned;
delete [] mat_b_val_partitioned;
MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY);
//Errors:
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Argument out of range
[1]PETSC ERROR: nnz cannot be greater than block row length: local row
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.5.0, Jun, 30, 2014
[1]PETSC ERROR: fetdem3dp on a arch-linux2-c-debug named n0024.voltaire0 by
esum Thu Nov  6 11:34:23 2014
[1]PETSC ERROR: Configure options
--prefix=/clusterfs/voltaire/home/software/modules/petsc/3.5.0
--download-fblaslapack=1 --download-mumps=1 --download-parmetis=1
--with-ptscotch=1
--with-ptscotch-dir=/clusterfs/voltaire/home/software/modules/scotch/5.1.12-gcc/
--download-scalapack --download-metis=1 --download-superlu=1
--download-superlu_dist=1 --download-hypre=1
--with-mpi-dir=/global/software/sl-6.x86_64/modules/gcc/4.4.7/openmpi/1.6.5-gcc/
[1]PETSC ERROR: #1 MatSeqSBAIJSetPreallocation_SeqSBAIJ() line 1599 in
/clusterfs/voltaire/home/software/source/petsc-3.5.0/src/mat/impls/sbaij/seq/sbaij.c
[1]PETSC ERROR: #2 MatSeqSBAIJSetPreallocation() line 2054 in
[1]PETSC ERROR: #3 MatMPISBAIJSetPreallocation_MPISBAIJ() line 1626 in
/clusterfs/voltaire/home/software/source/petsc-3.5.0/src/mat/impls/sbaij/mpi/mpisbaij.c
[1]PETSC ERROR: #4 MatMPISBAIJSetPreallocation() line 1930 in
[1]PETSC ERROR: Object is in wrong state
[1]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
argument 1 "mat" before MatSetValues()
trouble shooting.
--with-ptscotch=1
[1]PETSC ERROR: #5 MatSetValues() line 1110 in
/clusterfs/voltaire/home/software/source/petsc-3.5.0/src/mat/interface/matrix.c
PNT 7 Rank:1
argument 1 "mat" before MatAssemblyBegin()
trouble shooting.
--with-ptscotch=1
[1]PETSC ERROR: #6 MatAssemblyBegin() line 4799 in
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC ERROR:
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: ---------------------  Stack Frames
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR:       INSTEAD the line number of the start of the function
[1]PETSC ERROR:       is given.
[1]PETSC ERROR: [1] MatStashScatterEnd_Private line 112
/clusterfs/voltaire/home/software/source/petsc-3.5.0/src/mat/utils/matstash.c
[1]PETSC ERROR: [1] MatAssemblyEnd_MPISBAIJ line 517
[1]PETSC ERROR: [1] MatAssemblyEnd line 4892
[1]PETSC ERROR: [1] MatAssemblyBegin line 4796
[1]PETSC ERROR: [1] MatSetValues line 1103
[1]PETSC ERROR: [1] MatSeqSBAIJSetPreallocation_SeqSBAIJ line 1575
[1]PETSC ERROR: [1] MatSeqSBAIJSetPreallocation line 2050
[1]PETSC ERROR: [1] MatMPISBAIJSetPreallocation_MPISBAIJ line 1587
[1]PETSC ERROR: [1] MatMPISBAIJSetPreallocation line 1926
[1]PETSC ERROR: Signal received
trouble shooting.
--with-ptscotch=1
[1]PETSC ERROR: #7 User provided function() line 0 in  unknown file
PNT 5 Rank:2
PNT 5 Rank:0
[2]PETSC ERROR:
[2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
batch system) has told this process to end
[2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[2]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[2]PETSC ERROR:
corruption errors
[2]PETSC ERROR: likely location of problem given in stack below
[2]PETSC ERROR: ---------------------  Stack Frames
[2]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[2]PETSC ERROR:       INSTEAD the line number of the start of the function
[2]PETSC ERROR:       is given.
[2]PETSC ERROR: [2] MatSetValues line 1103
[2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Signal received
[2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[2]PETSC ERROR: Petsc Release Version 3.5.0, Jun, 30, 2014
[2]PETSC ERROR: fetdem3dp on a arch-linux2-c-debug named n0024.voltaire0 by
[2]PETSC ERROR: Configure options
--with-ptscotch=1
[2]PETSC ERROR: #1 User provided function() line 0 in  unknown file
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR:
corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] MatSetValues line 1103
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.0, Jun, 30, 2014
[0]PETSC ERROR: fetdem3dp on a arch-linux2-c-debug named n0024.voltaire0 by
[0]PETSC ERROR: Configure options
--with-ptscotch=1
[0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141106/f116473b/attachment.html>
