[petsc-users] Does KSPSetInitialGuessNonzero mean that x with initial values and will be updated?
Tue Nov 4 14:20:47 CST 2014
> On Nov 4, 2014, at 2:13 PM, Brian Yang <brianyang1106 at gmail.com> wrote:
> Hi all,
> I am trying to solve Ax=0 with an initial values of x. I know KSPSetInitialGuessNonzero is
> able to disable the zero guess, so it will keep updating the initial x right?
   What do you mean by “it will keep updating the initial x right”?  What is “it” and what do you mean by “keep updating”.
   If you have not called KSPSetInitialGuessNonzero() then KSPSolve() will automatically zero x before starting the iteration. If you do call KSPSetInitialGuessNonzero() then KSPSolve will not automatically zero x before starting the iteration. That is all it does.
  Barry
> Thanks.
> Brian Yang
> U of Houston
