[petsc-users] Speed up KSPSolve of dense matrix
Tue Nov 4 10:08:27 CST 2014
   There are a lot of questions here.
> On Nov 4, 2014, at 3:28 AM, Florian Lindner <mailinglists at xgm.de> wrote:
> Hello,
> I have a fulll matrix of size e.g. 603x603 of which I'm very disappointed with the runtime, compared to a naive LU / forward / backward solution. My petsc solution takes about 14s, while the old one takes just 0.5s. (when you're looking at sparse matrices the figures are almost inversed). I try to investigate what's the problem.
   For small problems like this direct dense LU could easily be faster than iterative schemes. Especially if you have many right hand sides with the same matrix since the factorization only needs to be done one.
> Most of the time is spent in the KSPSolve.
> Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
>                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> MatMult            10334 1.0 6.3801e+00 1.0 7.51e+09 1.0 0.0e+00 0.0e+00 0.0e+00 45 49  0  0  0  45 49  0  0  0  1177
> MatSolve           10334 1.0 6.9187e+00 1.0 7.51e+09 1.0 0.0e+00 0.0e+00 0.0e+00 49 49  0  0  0  49 49  0  0  0  1085
   If this is for a single solver for a 603 by 603 matrix then this is absurd.  10000 plus iterations
> MatCholFctrNum         1 1.0 1.8968e-01 1.0 6.03e+02 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> KSPGMRESOrthog     10000 1.0 2.1417e-01 1.0 3.73e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2  2  0  0  0   2  2  0  0  0  1744
> KSPSolve               1 1.0 1.3763e+01 1.0 1.54e+10 1.0 0.0e+00 0.0e+00 0.0e+00 97100  0  0  0  97100  0  0  0  1120
> Prealloc Matrix C       1 1.0 5.7458e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> Filling Matrix C       1 1.0 6.7984e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> VecMDot            10000 1.0 8.8615e-02 1.0 1.87e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  2106
> VecMAXPY           10334 1.0 1.2585e-01 1.0 1.99e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1580
> Prealloc Matrix A       1 1.0 1.1071e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> Filling Matrix A       1 1.0 1.2574e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> PCSetUp                1 1.0 1.9073e-01 1.0 6.03e+02 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
> PCApply            10334 1.0 6.9233e+00 1.0 7.51e+09 1.0 0.0e+00 0.0e+00 0.0e+00 49 49  0  0  0  49 49  0  0  0  1085
> Removed all events with global %T == 0, but my own ones.
> Matrix type is sequential MATSBAIJ on PETSC_COMM_SELF.
> KSP is initalized once:
>  KSPSetOperators(_solver, _matrixC.matrix, _matrixC.matrix);
>  KSPSetTolerances(_solver, _solverRtol, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
>  KSPSetFromOptions(_solver);
> KSPSolve:
>  ierr = KSPSolve(_solver, in.vector, p.vector); CHKERRV(ierr)
> KSPSolve may be executed multiple times with the same SetOperators acording to dimensionality of the data. Here it's just one.
> -ksp_view says:
> KSP Object: 1 MPI processes
>  type: gmres
>    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>    GMRES: happy breakdown tolerance 1e-30
>  maximum iterations=10000, initial guess is zero
>  tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
>  left preconditioning
>  using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>  type: icc
>    0 levels of fill
>    tolerance for zero pivot 2.22045e-14
>    using Manteuffel shift [POSITIVE_DEFINITE]
>    matrix ordering: natural
>    factor fill ratio given 1, needed 1
>      Factored matrix follows:
>        Mat Object:         1 MPI processes
>          type: seqsbaij
>          rows=603, cols=603
>          package used to perform factorization: petsc
>          total: nonzeros=182103, allocated nonzeros=182103
>          total number of mallocs used during MatSetValues calls =0
>              block size is 1
>  linear system matrix = precond matrix:
>  Mat Object:  C   1 MPI processes
>    type: seqsbaij
>    rows=603, cols=603
>        block size is 1
> I've tried to use a direct solver like suggested on pp 72, but:
> ./petBench 600 1 -ksp_type preonly -pc_type lu
  You cannot use LU with SBAIJ format. Only Cholesky. So use -pc_type cholesky
> Mesh of size: 600
> Do mappings: 1
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: Factor type not supported
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.2, unknown
> [0]PETSC ERROR: ./petBench on a arch-linux2-c-opt named helium by lindnefn Tue Nov  4 10:19:28 2014
> [0]PETSC ERROR: Configure options --with-debugging=0
> [0]PETSC ERROR: #1 MatGetFactor_seqsbaij_petsc() line 1833 in /data2/scratch/lindner/petsc/src/mat/impls/sbaij/seq/sbaij.c
> [0]PETSC ERROR: #2 MatGetFactor() line 3963 in /data2/scratch/lindner/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: #3 PCSetUp_LU() line 125 in /data2/scratch/lindner/petsc/src/ksp/pc/impls/factor/lu/lu.c
> [0]PETSC ERROR: #4 PCSetUp() line 902 in /data2/scratch/lindner/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #5 KSPSetUp() line 305 in /data2/scratch/lindner/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #6 KSPSolve() line 417 in /data2/scratch/lindner/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #7 map() line 391 in /data2/scratch/lindner/precice/src/mapping/PetRadialBasisFctMapping.hpp
> Any other idea about how to speed up that?
> Thanks for any suggestions!
> Florian
