[petsc-users] Multiple solves with PCMG fail
Jed Brown jed at jedbrown.org
Tue Nov 4 02:02:00 CST 2014
Filippo Leonardi <filippo.leonardi at sam.math.ethz.ch> writes:
> Sorry for the late update.
> I tested the code with the branch:
> ksp-zero-eig
> But the problem seems to still be there, also tried:
> -ksp_chebyshev_estimate_eigenvalues_random
> but does not change.
These are probably on levels, like
-mg_levels_ksp_chebyshev_estimate_eigenvalues_random, but perhaps you
set other prefixes or it's inside fieldsplit, etc.  Just use the correct
prefix for the solve that is failing.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141104/079ffcbc/attachment.pgp>
