[petsc-users] petsc-3.5.2: ex12 with Neumann BC
Olivier Bonnefon olivier.bonnefon at avignon.inra.fr
Mon Nov 3 03:46:21 CST 2014
Hello,
Thank for your answer, I'll explain my trouble:
My problem is that the BC Neumann leads to wrong result.
With Dirichlet BC, I get:
 > ./ex12 -run_type full -refinement_limit 0.0    -bc_type dirichlet
-interpolate 0 -petscspace_order 1 -show_initial -show_solution
-dm_plex_print_fem 1
Solution
Vec Object:potential 1 MPI processes
   type: seq
0.5
This result is correct.
With Neuman BC, I get:
 > ./ex12 -run_type full -refinement_limit 0.0    -bc_type neumann
-interpolate 1 -petscspace_order 1 -show_initial -dm_plex_print_fem 1
-show_solution -bd_petscspace_order 1 -snes_linesearch_monitor
-snes_monitor -ksp_monitor_true_residual -snes_converged_reason
-ksp_converged_reason
Solution
   type: seq
-0.75
-0.583333
0.0833333
-0.583333
-0.333333
0.416667
0.0833333
0.416667
1.25
That is not the values of the solution x*x+y*y.
I tried many ksp options.
Moreover, the neumann BC with "-run_type full" is not cover in the list
https://bitbucket.org/petsc/petsc/src/fced3c3f9e703542693913793d15321603e40fe6/config/builder.py?at=master#cl-257
Do you know what is wrong ?
Olivier Bonnefon
On 10/31/2014 06:50 PM, Matthew Knepley wrote:
> On Fri, Oct 31, 2014 at 10:43 AM, Olivier Bonnefon
> <olivier.bonnefon at avignon.inra.fr
> <mailto:olivier.bonnefon at avignon.inra.fr>> wrote:
>     Hello,
>     I'm working on the snes/examples/tutorial/ex12 version 3.5.2.
>     I didn't succed to run the simplest case with Neumann BC:
>     -dm_plex_print_fem 1 -show_solution -bd_petscspace_order 1
>     -snes_linesearch_monitor -snes_monitor -ksp_monitor_true_residual
>     -snes_converged_reason -ksp_converged_reason
>     This leads to dofs negatives values.
> I do not understand what you mean. Please always mail the full error
> message.
>     Do you know the options to get a correct result with Neumann BC ?
> There are some tests here:
>    Matt
>     Regards,
>     Olivier Bonnefon
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Olivier Bonnefon
INRA PACA-Avignon, Unité BioSP
Tel: +33 (0)4 32 72 21 58
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20141103/1228f9a9/attachment-0001.html>
