[petsc-users] rtol meaning
Danny Lathouwers - TNW D.Lathouwers at tudelft.nl
Fri May 30 03:11:02 CDT 2014
Thanks for the clarification. Petsc saves me a lot of time not having to write the icc etc so i can live with these small issues very well. Petsc behaves as expected now.
Danny
Sent from my iPad
> On 29 mei 2014, at 22:04, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>  Danny,
>   The manual pages are a little sloppy and inconsistent. By default it uses ||b|| or || preconditioned b|| as the starting point. At the bottom of the badly formatted page you’ll see "- - rnorm_0 is the two norm of the right hand side. When initial guess is non-zero you can call KSPDefaultConvergedSetUIRNorm() to use the norm of (b - A*(initial guess)) as the starting point for relative norm convergence testing."
> Likely you want to call KSPDefaultConvergedSetUIRNorm if that is how you want to detect convergence.
>   We’ll cleanup the manual pages, thanks for pointing out the confusion.
>   Barry
>  You can see the source code at http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/interface/iterativ.c.html#KSPDefaultConverged and confirm that what Matt said is correct.
>> On May 29, 2014, at 2:49 PM, Danny Lathouwers - TNW <D.Lathouwers at tudelft.nl> wrote:
>> Thanks Matt for your quick response.
>> I got to believe that it was the relative ratio of the residual from the following petsc links:
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetTolerances.html
>> and
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPDefaultConverged.html#KSPDefaultConverged
>> Perhaps these pages are outdated?
>> Cheers,
>> Danny.
