[petsc-users] rtol meaning
Thu May 29 11:58:51 CDT 2014
On Thu, May 29, 2014 at 11:31 AM, Danny Lathouwers - TNW <
D.Lathouwers at tudelft.nl> wrote:
>  Dear users,
> I have a problem where I step time and repeatedly solve a system with
> differing rhs.
> At some time step petsc solver returns that initial solution is good
> enough (converged reason = 2 with 0 iterations done).
> I do not expect this behaviour. I use rtol = 0.001, atol=0 and dtol =large
> number.
> The manual seems to suggest the criterion is: rnorm < MAX (rtol * rnorm_0, abstol) (probably based on preconditioned residual).
> How could this lead to zero iterations being done? Or is the criterion based on rnorm/bnorm instead (which I found in some reference on the internet concerning petsc and would explain the observed behaviour).
> Its ||b||, not ||r_0||. You can change it to get the other behavior, as
detailed here
http://www.mcs.anl.gov/petsc/petsc-dev/src/ksp/ksp/interface/iterativ.c.html#KSPConvergedDefault
     Matt
> Thanks,
> Danny.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140529/fa9f6a24/attachment.html>
