[petsc-users] Set the directory of output file
Tue May 27 15:40:27 CDT 2014
On Tue, 27 May 2014, Likun Tan wrote:
> Hello,
> I want to create and write my simulation result in a binary file called result.dat, but I want to set my file in a different folder, say /home/username/output
> I am using
> PetscViewerBinaryOpen(PETSC_COMM_WORLD, result.dat, FILE_MODE_WRITE, & view)
> But this will create the file in the current folder by default. How could I modify the command to set a new path? Thank you.
You should be able to do:
PetscViewerBinaryOpen(PETSC_COMM_WORLD, "/home/username/output/result.dat", FILE_MODE_WRITE, & view)
[or specify the path to the output file at runtime and use
PetscOptionsGetString() to extract this string and use with
PetscViewerBinaryOpen(). For ex: check '-f0' usage in
src/ksp/ksp/examples/tutorials/ex10.c]
Satish
