[petsc-users] ExodusII
Jed Brown jed at jedbrown.org
Mon May 26 08:17:17 CDT 2014
Pedro Rodrigues <pjsgr100 at gmail.com> writes:
> Hi
>    I successfully built EXODUSII under Windows using netCDF, HDF5
> (ZLIB and SZIP also). I ran an example to mesh generation with success. I
> would like to ask you to add support to EXODUSII under this
> platform. Fortran bindings are not there (or don't work) but I made that
> with Fortran interfaces (that can also be done with 'c' directives).
The best way to add support is to have upstream accept your patch to
make ExodusII compatible.  The second best way is to submit a patch to
PETSc.
> VS2012 does not contain inttypes.h but I modified a cygwin file to
> make that available.
This sounds problematic because installing packages should not involve
modifying system files.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140526/0f55ba05/attachment-0001.pgp>
