[petsc-users] Installation problems on IBM machine
Samar Khatiwala spk at ldeo.columbia.edu
Sat May 24 07:04:07 CDT 2014
Hello,
I'm having trouble installing PETSc on an IBM machine (power6). After some trial and error I managed to configure but the 'make all' step fails with:
Building PETSc using CMake with 21 build threads
make: 1254-002 Cannot find a rule to create target 21 from dependencies.
Stop.
make: 1254-004 The error code from the last command is 2.
Please see attached logs. I configured with:
config/configure.py --with-cc=mpcc --with-cxx=mpCC --with-clanguage=c --with-fc=mpxlf90 --with-debugging=0 FFLAGS="-qextname" --with-batch=1 --known-mpi-shared-libraries=0 --with-blas-lapack-lib="[libessl.a]"
What is odd is that this worked once but 'make test' failed because of a missing LAPACK routine in ESSL. I reconfigured with
--with-blas-lib=libessl.a --with-lapack-lib=/sw/aix53/lapack-3.2.0/lib/liblapack.a but then 'make all' failed with the same error as I now
get *even after* reverting to the original (above) configure options. I've now tried this several times with a fresh copy of PETSc to no
avail.
Any help would be appreciated. Thanks very much!
Samar
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140524/7394b6be/attachment-0002.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140524/7394b6be/attachment-0003.bin>
