[petsc-users] Question on local vec to global vec for dof > 1
Danyang Su danyang.su at gmail.com
Thu May 22 13:58:10 CDT 2014
Hi All,
I have a 1D transient flow problem (1 dof) coupled with energy balance
(1 dof), so the total dof per node is 2.
The whole domain has 10 nodes in z direction.
The program runs well with 1 processor but failed in 2 processors. The
matrix is the same for 1 processor and 2 processor but the rhs are
different.
The following is used to set the rhs value.
call VecGetArrayF90(x_vec_loc, vecpointer, ierr)
vecpointer = (calculate the rhs value here)
call VecRestoreArrayF90(x_vec_loc,vecpointer,ierr)
call DMLocalToGlobalBegin(da,x_vec_loc,INSERT_VALUES, x_vec_gbl,ierr)
call DMLocalToGlobalEnd(da,x_vec_loc,INSERT_VALUES, x_vec_gbl,ierr)
*Vecview  Correct * *Vecview Wrong*
dof     local node           Process [0] _Process [0] _ /_Process [0] _/
1            1              1.395982780116148E-021
1.39598e-021                 1.39598e-021
1            2              0.000000000000000E+000
0                                       0
1            3              0.000000000000000E+000
0                                       0
1            4              5.642372883946980E-037
5.64237e-037                 5.64237e-037
1            5              0.000000000000000E+000
0                                       0
1            6 -1.395982780116148E-021 -7.52316e-037
-1.39598e-021 Line A
2            1 0.000000000000000E+000 7.52316e-037                 0
2            2 0.000000000000000E+000 0 0
2            3 0.000000000000000E+000 1.68459e-016 0
2            4 4.814824860968090E-035 0.1296 4.81482e-035
2            5 0.000000000000000E+000 _/Process [1]/_ Line B
2            6 -1.371273884908092E-019 0
7.52316e-037                       Line C
0               0
                                        Process [1] 0 1.68459e-016
1            1 1.395982780116148E-021 4.81482e-035
0.1296                                     Line D
1            2 -7.523163845262640E-037 0
1.37127e-019                         Line E
1            3 7.523163845262640E-037 -7.22224e-035
-7.22224e-035
1            4 0.000000000000000E+000 7.22224e-035
7.22224e-035
1            5 1.684590875336239E-016
0                                       0
1            6 0.129600000000000
128623                            128623
2            1 1.371273884908092E-019
0                                       0 Line F
2            2             -7.222237291452134E-035
2            3              7.222237291452134E-035
2            4              0.000000000000000E+000
2            5               128623.169844761
2            6              0.000000000000000E+000
The red line (Line A, C, D and F) is the ghost values for 2 subdomains,
but when run with 2 processor, the program treates Line B, C, D, and E
as ghost values.
*How can I handle this kind of local vector to global vector assembly?*
*In fact, the codes can work if the dof and local node is as follows.*
dof     local node
1            1
2            1
1            2
2            2
1            3
2            3
Thanks and regards,
Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140522/ffb3c3a4/attachment-0001.html>
