[petsc-users] Non-matching KSP and SNES norms during SNES solve
Thu May 22 12:52:07 CDT 2014
On Thu, May 22, 2014 at 12:47 PM, Jean-Arthur Louis Olive
<jaolive at mit.edu>wrote:
> Hi Barry,
> sorry about the late reply-
> We indeed use structured grids (DMDA 2d) - but do not ever provide a
> Jacobian for our non-linear stokes problem (instead just rely on petsc's FD
> approximation). I understand "snes_type test" is meant to compare petsc’s
> Jacobian with a user-provided analytical Jacobian.
> Are you saying we should provide an exact Jacobian for our simple linear
> test and see if there’s a problem with the approximate Jacobian?
The Jacobian computed by PETSc uses a finite-difference approximation, and
thus is only accurate to maybe 1.0e-7
depending on the conditioning of your system. Are you trying to compare
things that are more precise than that? You
can provide an exact Jacobian to get machine accuracy.
  Matt
> Thanks,
> Arthur & Eric
> >   If you are using DMDA and either DMGetColoring or the SNESSetDM
> approach and dof is 4 then we color each of the 4 variables per grid point
> with a different color so coupling between variables within a grid point is
> not a problem. This would not explain the problem you are seeing below.
> >   Run your code with -snes_type test and read the results and follow the
> directions to debug your Jacobian.
> >   Barry
> > On May 13, 2014, at 1:20 PM, Jean-Arthur Louis Olive <jaolive at MIT.EDU>
> wrote:
> >> Hi all,
> >> we are using PETSc to solve the steady state Stokes equations with
> non-linear viscosities using finite difference. Recently we have realized
> that our true residual norm after the last KSP solve did not match next
> SNES function norm when solving the linear Stokes equations.
> >> So to understand this better, we set up two extremely simple linear
> residuals, one with no coupling between variables (vx, vy, P and T), the
> other with one coupling term (shown below).
> >> RESIDUAL 1 (NO COUPLING):
> >>  for (j=info->ys; j<info->ys+info->ym; j++) {
> >>    for (i=info->xs; i<info->xs+info->xm; i++) {
> >>      f[j][i].P = x[j][i].P - 3000000;
> >>      f[j][i].vx= 2*x[j][i].vx;
> >>      f[j][i].vy= 3*x[j][i].vy - 2;
> >>      f[j][i].T = x[j][i].T;
> >> RESIDUAL 2 (ONE COUPLING TERM):
> >>      f[j][i].P = x[j][i].P - 3;
> >>      f[j][i].vx= x[j][i].vx - 3*x[j][i].vy;
> >>      f[j][i].vy= x[j][i].vy - 2;
> >> and our default set of options is:
> >> OPTIONS:  mpiexec -np $np ../Stokes -snes_max_it 4 -ksp_atol 2.0e+2
> -ksp_max_it 20 -ksp_rtol 9.0e-1 -ksp_type fgmres -snes_monitor
> -snes_converged_reason -snes_view -log_summary -options_left 1
> -ksp_monitor_true_residual -pc_type none -snes_linesearch_type cp
> >> With the uncoupled residual (Residual 1), we get matching KSP and SNES
> norm, highlighted below:
> >> Result from Solve - RESIDUAL 1
> >>  0 SNES Function norm 8.485281374240e+07
> >>    0 KSP unpreconditioned resid norm 8.485281374240e+07 true resid norm
> 8.485281374240e+07 ||r(i)||/||b|| 1.000000000000e+00
> >>    1 KSP unpreconditioned resid norm 1.131370849896e+02 true resid norm
> 1.131370849896e+02 ||r(i)||/||b|| 1.333333333330e-06
> >>  1 SNES Function norm 1.131370849896e+02
> >>    0 KSP unpreconditioned resid norm 1.131370849896e+02 true resid norm
> 1.131370849896e+02 ||r(i)||/||b|| 1.000000000000e+00
> >>  2 SNES Function norm 1.131370849896e+02
> >> Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 2
> >> With the coupled residual (Residual 2), the norms do not match, see
> below
> >> Result from Solve - RESIDUAL 2:
> >>  0 SNES Function norm 1.019803902719e+02
> >>    0 KSP unpreconditioned resid norm 1.019803902719e+02 true resid norm
> 1.019803902719e+02 ||r(i)||/||b|| 1.000000000000e+00
> >>    1 KSP unpreconditioned resid norm 8.741176309016e+01 true resid norm
> 8.741176309016e+01 ||r(i)||/||b|| 8.571428571429e-01
> >>  1 SNES Function norm 1.697056274848e+02
> >>    0 KSP unpreconditioned resid norm 1.697056274848e+02 true resid norm
> 1.697056274848e+02 ||r(i)||/||b|| 1.000000000000e+00
> >>    1 KSP unpreconditioned resid norm 5.828670868165e-12 true resid norm
> 5.777940247956e-12 ||r(i)||/||b|| 3.404683942184e-14
> >>  2 SNES Function norm 3.236770473841e-07
> >> Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 2
> >> Lastly, if we add -snes_fd to our options, the norms for residual 2 get
> better - they match after the first iteration but not after the second.
> >> Result from Solve with -snes_fd - RESIDUAL 2
> >>    1 KSP unpreconditioned resid norm 2.039607805429e+02 true resid norm
> 2.039607805429e+02 ||r(i)||/||b|| 2.403700850300e-06
> >>  1 SNES Function norm 2.039607805429e+02
> >>    0 KSP unpreconditioned resid norm 2.039607805429e+02 true resid norm
> 2.039607805429e+02 ||r(i)||/||b|| 1.000000000000e+00
> >>    1 KSP unpreconditioned resid norm 2.529822128436e+01 true resid norm
> 2.529822128436e+01 ||r(i)||/||b|| 1.240347346045e-01
> >>  2 SNES Function norm 2.549509757105e+01 [SLIGHTLY DIFFERENT]
> >>    0 KSP unpreconditioned resid norm 2.549509757105e+01 true resid norm
> 2.549509757105e+01 ||r(i)||/||b|| 1.000000000000e+00
> >>  3 SNES Function norm 2.549509757105e+01
> >> Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 3
> >> Does this mean that our Jacobian is not approximated properly by the
> default “coloring” method when it has off-diagonal terms?
> >> Thanks a lot,
> >> Arthur and Eric
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140522/753d8143/attachment.html>
