[petsc-users] Error message for DMShell using MG preconditioner to solve S
Luc Berger-Vergiat lb2653 at columbia.edu
Wed May 21 14:09:23 CDT 2014
So I just pulled an updated version of petsc-dev today (I switched from
the *next* branch to the *master* branch due to some compilation error
existing with the last commit on *next*).
I still have the same error and I believe this is the whole error
message I have.
I mean I am running multiple time steps for my simulation so I have the
same message at each time step, but I don't think that it is important
to report these duplicates, is it?
Best,
Luc
On 05/20/2014 09:14 PM, Matthew Knepley wrote:
> On Tue, May 20, 2014 at 4:33 PM, Luc Berger-Vergiat
> <lb2653 at columbia.edu <mailto:lb2653 at columbia.edu>> wrote:
>     Hi all,
>     I am running an FEM simulation that uses Petsc as a linear solver.
>     I am setting up ISs and pass them to a DMShell in order to use the
>     FieldSplit capabilities of Petsc.
>     When I pass the following options to Petsc:
>         " -ksp_type gmres -pc_type fieldsplit -pc_fieldsplit_type
>         schur -pc_fieldsplit_schur_factorization_type full
>         -pc_fieldsplit_schur_precondition selfp
>         -pc_fieldsplit_0_fields 1,2 -pc_fieldsplit_1_fields 0
>         -fieldsplit_0_ksp_type preonly -fieldsplit_0_pc_type ilu
>         -fieldsplit_Field_0_ksp_type gmres -fieldsplit_Field_0_pc_type
>         mg -malloc_log mlog -log_summary time.log"
>     I get an error message:
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Must call DMShellSetGlobalVector() or
>     DMShellSetCreateGlobalVector()
>     [0]PETSC ERROR: See
>     http://http://www.mcs.anl.gov/petsc/documentation/faq.html for
>     trouble shooting.
>     [0]PETSC ERROR: Petsc Development GIT revision:
>     v3.4.4-5071-g1163a46  GIT Date: 2014-03-26 22:20:51 -0500
>     [0]PETSC ERROR:
>     /home/luc/research/feap_repo/ShearBands/parfeap-dev/feap on a
>     arch-linux2-c-opt named euler by luc Tue May 20 11:31:11 2014
>     [0]PETSC ERROR: Configure options --download-cmake
>     --download-hypre --download-metis --download-mpich
>     --download-parmetis --with-debugging=no --with-share-libraries=no
>     [0]PETSC ERROR: #1 DMCreateGlobalVector_Shell() line 245 in
>     /home/luc/research/petsc/src/dm/impls/shell/dmshell.c
>     [0]PETSC ERROR: #2 DMCreateGlobalVector() line 669 in
>     /home/luc/research/petsc/src/dm/interface/dm.c
>     [0]PETSC ERROR: #3 DMGetGlobalVector() line 154 in
>     /home/luc/research/petsc/src/dm/interface/dmget.c
> Always always always give the entire error message.
>   Matt
>     I am not really sure why this happens but it only happens when
>     -fieldsplit_Field_0_pc_type mg, with other preconditioners, I have
>     no problems. I attached the ksp_view in case that's any use.
>     Best,
>     Luc
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140521/6db2d72d/attachment.html>
