[petsc-users] Error message for DMShell using MG preconditioner to solve S
Luc Berger-Vergiat lb2653 at columbia.edu
Tue May 20 16:33:18 CDT 2014
Hi all,
I am running an FEM simulation that uses Petsc as a linear solver.
I am setting up ISs and pass them to a DMShell in order to use the
FieldSplit capabilities of Petsc.
When I pass the following options to Petsc:
    " -ksp_type gmres -pc_type fieldsplit -pc_fieldsplit_type schur
    -pc_fieldsplit_schur_factorization_type full
    -pc_fieldsplit_schur_precondition selfp -pc_fieldsplit_0_fields 1,2
    -pc_fieldsplit_1_fields 0 -fieldsplit_0_ksp_type preonly
    -fieldsplit_0_pc_type ilu -fieldsplit_Field_0_ksp_type gmres
    -fieldsplit_Field_0_pc_type mg -malloc_log mlog -log_summary time.log"
I get an error message:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR:
[0]PETSC ERROR: Must call DMShellSetGlobalVector() or
DMShellSetCreateGlobalVector()
[0]PETSC ERROR: See
http://http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5071-g1163a46
GIT Date: 2014-03-26 22:20:51 -0500
[0]PETSC ERROR: /home/luc/research/feap_repo/ShearBands/parfeap-dev/feap
on a arch-linux2-c-opt named euler by luc Tue May 20 11:31:11 2014
[0]PETSC ERROR: Configure options --download-cmake --download-hypre
--download-metis --download-mpich --download-parmetis
--with-debugging=no --with-share-libraries=no
[0]PETSC ERROR: #1 DMCreateGlobalVector_Shell() line 245 in
/home/luc/research/petsc/src/dm/impls/shell/dmshell.c
[0]PETSC ERROR: #2 DMCreateGlobalVector() line 669 in
/home/luc/research/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #3 DMGetGlobalVector() line 154 in
/home/luc/research/petsc/src/dm/interface/dmget.c
I am not really sure why this happens but it only happens when
-fieldsplit_Field_0_pc_type mg, with other preconditioners, I have no
problems. I attached the ksp_view in case that's any use.
Best,
Luc
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140520/0c1e7f70/attachment-0001.html>
KSP Object: 1 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-08, absolute=1e-16, divergence=1e+16
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, factorization FULL
    Preconditioner for the Schur complement formed from Sp, an assembled approximation to S, which uses A00's diagonal's inverse
    Split info:
    Split number 0 Defined by IS
    Split number 1 Defined by IS
    KSP solver for A00 block
      KSP Object:      (fieldsplit_0_)       1 MPI processes
        type: preonly
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
        using NONE norm type for convergence test
      PC Object:      (fieldsplit_0_)       1 MPI processes
        type: ilu
          ILU: out-of-place factorization
          0 levels of fill
          tolerance for zero pivot 2.22045e-14
          using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
          matrix ordering: natural
          factor fill ratio given 1, needed 1
            Factored matrix follows:
              Mat Object:               1 MPI processes
                type: seqaij
                rows=2000, cols=2000
                package used to perform factorization: petsc
                total: nonzeros=40000, allocated nonzeros=40000
                total number of mallocs used during MatSetValues calls =0
                  using I-node routines: found 400 nodes, limit used is 5
        linear system matrix = precond matrix:
        Mat Object:        (fieldsplit_0_)         1 MPI processes
          type: seqaij
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (fieldsplit_Field_0_)       1 MPI processes
        type: gmres
      PC Object:      (fieldsplit_Field_0_)       1 MPI processes
        type: mg
          MG: type is MULTIPLICATIVE, levels=1 cycles=v
            Cycles per PCApply=1
            Not using Galerkin computed coarse grid matrices
        Coarse grid solver -- level -------------------------------
          KSP Object:          (fieldsplit_Field_0_mg_levels_0_)           1 MPI processes
            type: chebyshev
              Chebyshev: eigenvalue estimates:  min = 0.937483, max = 10.3123
              Chebyshev: estimated using:  [0 0.1; 0 1.1]
              KSP Object:              (fieldsplit_Field_0_mg_levels_0_est_)               1 MPI processes
                type: gmres
                maximum iterations=10, initial guess is zero
              PC Object:              (fieldsplit_Field_0_mg_levels_0_)               1 MPI processes
                type: sor
                  SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
                linear system matrix followed by preconditioner matrix:
                Mat Object:                (fieldsplit_Field_0_)                 1 MPI processes
                  type: schurcomplement
                  rows=209, cols=209
                    Schur complement A11 - A10 inv(A00) A01
                    A11
                        type: seqaij
                        rows=209, cols=209
                        total: nonzeros=3209, allocated nonzeros=3209
                          using I-node routines: found 119 nodes, limit used is 5
                    A10
                        type: seqaij
                        rows=209, cols=2000
                        total: nonzeros=14800, allocated nonzeros=14800
                    KSP of A00
                        type: preonly
                        type: ilu
                          0 levels of fill
                                type: seqaij
                          type: seqaij
                    A01
                        type: seqaij
                        rows=2000, cols=209
                  type: seqaij
                  rows=209, cols=209
            maximum iterations=1, initial guess is zero
            type: sor
              rows=209, cols=209
                A11
                    type: seqaij
                    rows=209, cols=209
                A10
                    type: seqaij
                    rows=209, cols=2000
                KSP of A00
                    type: preonly
                    type: ilu
                      0 levels of fill
                            type: seqaij
                      type: seqaij
                A01
                    type: seqaij
                    rows=2000, cols=209
              type: seqaij
              rows=209, cols=209
          rows=209, cols=209
            A11
                type: seqaij
                rows=209, cols=209
            A10
                type: seqaij
                rows=209, cols=2000
            KSP of A00
                type: preonly
                type: ilu
                  0 levels of fill
                        type: seqaij
                  type: seqaij
            A01
                type: seqaij
                rows=2000, cols=209
          type: seqaij
          rows=209, cols=209
    type: seqaij
    rows=2209, cols=2209
    total: nonzeros=72809, allocated nonzeros=72809
      using I-node routines: found 519 nodes, limit used is 5
