[petsc-users] Problem with DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
Mon May 19 05:32:09 CDT 2014
On Mon, May 19, 2014 at 1:26 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 19/5/2014 11:36 AM, Barry Smith wrote:
>> On May 18, 2014, at 10:28 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>  On 19/5/2014 9:53 AM, Matthew Knepley wrote:
>>>> On Sun, May 18, 2014 at 8:18 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> Hi Barry,
>>>> I am trying to sort out the details so that it's easier to pinpoint the
>>>> error. However, I tried on gnu gfortran and it worked well. On intel ifort,
>>>> it stopped at one of the "DMDAVecGetArrayF90". Does it definitely mean that
>>>> it's a bug in ifort? Do you work with both intel and gnu?
>>>> Yes it works with Intel. Is this using optimization?
>>> Hi Matt,
>>> I forgot to add that in non-optimized cases, it works with gnu and
>>> intel. However, in optimized cases, it works with gnu, but not intel.  Does
>>> it definitely mean that it's a bug in ifort?
>>    No. Does it run clean under valgrind?
> Hi,
> Do you mean the debug or optimized version?
optimized. Have you tried using a lower optimization level?
   Matt
> Thanks.
>>     Matt
>>>> Thank you
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> On 14/5/2014 12:03 AM, Barry Smith wrote:
>>>>     Please send you current code. So we may compile and run it.
>>>>     Barry
>>>>     On May 12, 2014, at 9:52 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> Hi,
>>>> I have sent the entire code a while ago. Is there any answer? I was
>>>> also trying myself but it worked for some intel compiler, and some not. I'm
>>>> still not able to find the answer. gnu compilers for most cluster are old
>>>> versions so they are not able to compile since I have allocatable
>>>> structures.
>>>> Thank you.
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> On 21/4/2014 8:58 AM, Barry Smith wrote:
>>>>      Please send the entire code. If we can run it and reproduce the
>>>> problem we can likely track down the issue much faster than through endless
>>>> rounds of email.
>>>>      Barry
>>>> On Apr 20, 2014, at 7:49 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> On 20/4/2014 8:39 AM, TAY wee-beng wrote:
>>>> On 20/4/2014 1:02 AM, Matthew Knepley wrote:
>>>> On Sat, Apr 19, 2014 at 10:49 AM, TAY wee-beng <zonexo at gmail.com>
>>>> wrote:
>>>> On 19/4/2014 11:39 PM, Matthew Knepley wrote:
>>>> On Sat, Apr 19, 2014 at 10:16 AM, TAY wee-beng <zonexo at gmail.com>
>>>> wrote:
>>>> On 19/4/2014 10:55 PM, Matthew Knepley wrote:
>>>> On Sat, Apr 19, 2014 at 9:14 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> On 19/4/2014 6:48 PM, Matthew Knepley wrote:
>>>> On Sat, Apr 19, 2014 at 4:59 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> On 19/4/2014 1:17 PM, Barry Smith wrote:
>>>> On Apr 19, 2014, at 12:11 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> On 19/4/2014 12:10 PM, Barry Smith wrote:
>>>> On Apr 18, 2014, at 9:57 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> On 19/4/2014 3:53 AM, Barry Smith wrote:
>>>>      Hmm,
>>>>          Interface DMDAVecGetArrayF90
>>>>            Subroutine DMDAVecGetArrayF903(da1, v,d1,ierr)
>>>>              USE_DM_HIDE
>>>>              DM_HIDE da1
>>>>              VEC_HIDE v
>>>>              PetscScalar,pointer :: d1(:,:,:)
>>>>              PetscErrorCode ierr
>>>>            End Subroutine
>>>>       So the d1 is a F90 POINTER. But your subroutine seems to be
>>>> treating it as a “plain old Fortran array”?
>>>> real(8), intent(inout) :: u(:,:,:),v(:,:,:),w(:,:,:)
>>>> Hi,
>>>> So d1 is a pointer, and it's different if I declare it as "plain old
>>>> Fortran array"? Because I declare it as a Fortran array and it works w/o
>>>> any problem if I only call DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
>>>> with "u".
>>>> But if I call DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90 with "u",
>>>> "v" and "w", error starts to happen. I wonder why...
>>>> Also, supposed I call:
>>>> call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>>>>       call DMDAVecGetArrayF90(da_v,v_local,v_array,ierr)
>>>>       call DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)
>>>> u_array ....
>>>> v_array .... etc
>>>> Now to restore the array, does it matter the sequence they are restored?
>>>>       No it should not matter. If it matters that is a sign that memory
>>>> has been written to incorrectly earlier in the code.
>>>> Hi,
>>>> Hmm, I have been getting different results on different intel
>>>> compilers. I'm not sure if MPI played a part but I'm only using a single
>>>> processor. In the debug mode, things run without problem. In optimized
>>>> mode, in some cases, the code aborts even doing simple initialization:
>>>>       call DMDAVecGetArrayF90(da_p,p_local,p_array,ierr)
>>>>       u_array = 0.d0
>>>>       v_array = 0.d0
>>>>       w_array = 0.d0
>>>>       p_array = 0.d0
>>>>       call DMDAVecRestoreArrayF90(da_p,p_local,p_array,ierr)
>>>>       call DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)
>>>>       call DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr)
>>>>       call DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr)
>>>> The code aborts at call DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr),
>>>> giving segmentation error. But other
>>>>                                               version of intel compiler
>>>> passes thru this part w/o error. Since the response is different among
>>>> different compilers, is this PETSc or intel 's bug? Or mvapich or openmpi?
>>>> We do this is a bunch of examples. Can you reproduce this different
>>>> behavior in src/dm/examples/tutorials/ex11f90.F?
>>>> Hi Matt,
>>>> Do you mean putting the above lines into ex11f90.F and test?
>>>> It already has DMDAVecGetArray(). Just run it.
>>>> Hi,
>>>> It worked. The differences between mine and the code is the way the
>>>> fortran modules are defined, and the ex11f90 only uses global vectors. Does
>>>> it make a difference whether global or local vectors are used? Because the
>>>> way it accesses x1 only touches the local region.
>>>> No the global/local difference should not matter.
>>>>    Also, before using DMDAVecGetArrayF90, DMGetGlobalVector must be
>>>> used 1st, is that so? I can't find the equivalent for local vector though.
>>>> DMGetLocalVector()
>>>> Ops, I do not have DMGetLocalVector and DMRestoreLocalVector in my
>>>> code. Does it matter?
>>>> If so, when should I call them?
>>>> You just need a local vector from somewhere.
>>>> Hi,
>>>> Anyone can help with the questions below? Still trying to find why my
>>>> code doesn't work.
>>>> Thanks.
>>>> Hi,
>>>> I insert part of my error region code into ex11f90:
>>>>       u_array = 0.d0
>>>>            v_array = 0.d0
>>>>            w_array = 0.d0
>>>>            p_array = 0.d0
>>>> It worked w/o error. I'm going to change the way the modules are
>>>> defined in my code.
>>>> My code contains a main program and a number of modules files, with
>>>> subroutines inside e.g.
>>>> module solve
>>>>                    <- add include file?
>>>> subroutine RRK
>>>> end subroutine RRK
>>>> end module solve
>>>> So where should the include files (#include <finclude/petscdmda.h90>)
>>>> be placed?
>>>> After the module or inside the subroutine?
>>>> Thanks.
>>>>     Matt
>>>>    Thanks.
>>>>      Matt
>>>>    Thanks.
>>>>      Matt
>>>>    Thanks
>>>> Regards.
>>>>      Matt
>>>>    As in w, then v and u?
>>>> thanks
>>>>       Note also that the beginning and end indices of the u,v,w, are
>>>> different for each process see for example
>>>> http://www.mcs.anl.gov/petsc/petsc-3.4/src/dm/examples/
>>>> tutorials/ex11f90.F  (and they do not start at 1). This is how to get
>>>> the loop bounds.
>>>> Hi,
>>>> In my case, I fixed the u,v,w such that their indices are the same. I
>>>> also checked using DMDAGetCorners and DMDAGetGhostCorners. Now the problem
>>>> lies in my subroutine treating it as a “plain old Fortran array”.
>>>> If I declare them as pointers, their indices follow the C 0 start
>>>> convention, is that so?
>>>>       Not really. It is that in each process you need to access them
>>>> from the indices indicated by DMDAGetCorners() for global vectors and
>>>>                           DMDAGetGhostCorners() for local vectors.  So
>>>> really C or Fortran
>>>>   doesn’t make any difference.
>>>> So my problem now is that in my old MPI code, the u(i,j,k) follow the
>>>> Fortran 1 start convention. Is there some way to manipulate such that I do
>>>> not have to change my u(i,j,k) to u(i-1,j-1,k-1)?
>>>>      If you code wishes to access them with indices plus one from the
>>>> values returned by DMDAGetCorners() for global vectors and
>>>> DMDAGetGhostCorners() for local vectors then you need to manually subtract
>>>> off the 1.
>>>>      Barry
>>>> Thanks.
>>>>      Barry
>>>> On Apr 18, 2014, at 10:58 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> Hi,
>>>> I tried to pinpoint the problem. I reduced my job size and hence I can
>>>> run on 1 processor. Tried using valgrind but perhaps I'm using the
>>>> optimized version, it didn't catch the error, besides saying "Segmentation
>>>> fault (core dumped)"
>>>> However, by re-writing my code, I found out a few things:
>>>> 1. if I write my code this way:
>>>> u_array = ....
>>>> v_array = ....
>>>> w_array = ....
>>>> The code runs fine.
>>>> 2. if I write my code this way:
>>>> call uvw_array_change(u_array,v_array,w_array) -> this subroutine does
>>>> the same modification as the above.
>>>> call DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr) -> error
>>>> where the subroutine is:
>>>> subroutine uvw_array_change(u,v,w)
>>>> u ...
>>>> v...
>>>> w ...
>>>> end subroutine uvw_array_change.
>>>> The above will give an error at :
>>>> 3. Same as above, except I change the order of the last 3 lines to:
>>>> So they are now in reversed order. Now it works.
>>>> 4. Same as 2 or 3, except the subroutine is changed to :
>>>> real(8), intent(inout) :: u(start_indices(1):end_
>>>> indices(1),start_indices(2):end_indices(2),start_indices(
>>>> 3):end_indices(3))
>>>> real(8), intent(inout) :: v(start_indices(1):end_
>>>> 3):end_indices(3))
>>>> real(8), intent(inout) :: w(start_indices(1):end_
>>>> 3):end_indices(3))
>>>> u ...
>>>> v...
>>>> w ...
>>>> The start_indices and end_indices are simply to shift the 0 indices of
>>>> C convention to that of the 1 indices of the Fortran convention. This is
>>>> necessary in my case because most of my codes start array counting at 1,
>>>> hence the "trick".
>>>> However, now no matter which order of the DMDAVecRestoreArrayF90 (as in
>>>> 2 or 3), error will occur at "call DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr)
>>>> So did I violate and cause memory corruption due to the trick above?
>>>> But I can't think of any way other
>>>>                   than the "trick" to continue using the 1 indices
>>>> convention.
>>>> Thank you.
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> On 15/4/2014 8:00 PM, Barry Smith wrote:
>>>>      Try running under valgrind http://www.mcs.anl.gov/petsc/
>>>> documentation/faq.html#valgrind
>>>> On Apr 14, 2014, at 9:47 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> Hi Barry,
>>>> As I mentioned earlier, the code works fine in PETSc debug mode but
>>>> fails in non-debug mode.
>>>> I have attached my code.
>>>> Thank you
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> On 15/4/2014 2:26 AM, Barry Smith wrote:
>>>>      Please send the code that creates da_w and the declarations of
>>>> w_array
>>>>      Barry
>>>> On Apr 14, 2014, at 9:40 AM, TAY wee-beng
>>>>     wrote:
>>>> Hi Barry,
>>>> I'm not too sure how to do it. I'm running mpi. So I run:
>>>>     mpirun -n 4 ./a.out -start_in_debugger
>>>> I got the msg below. Before the gdb windows appear (thru x11), the
>>>> program aborts.
>>>> Also I tried running in another cluster and it worked. Also tried in
>>>> the current cluster in debug mode and it worked too.
>>>> An MPI process has executed an operation involving a call to the
>>>> "fork()" system call to create a child process.  Open MPI is currently
>>>> operating in a condition that could result in memory corruption or
>>>> other system errors; your MPI job may hang, crash, or produce silent
>>>> data corruption.  The use of fork() (or system() or other calls that
>>>> create child processes) is strongly discouraged.
>>>> The process that invoked fork was:
>>>>      Local host:          n12-76 (PID 20235)
>>>>      MPI_COMM_WORLD rank: 2
>>>> If you are *absolutely sure* that your application will successfully
>>>> and correctly survive a call to fork(), you may disable this warning
>>>> by setting the mpi_warn_on_fork MCA parameter to 0.
>>>> [2]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20235 on display
>>>> localhost:50.0 on machine n12-76
>>>> [0]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20233 on display
>>>> [1]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20234 on display
>>>> [3]PETSC ERROR: PETSC: Attaching gdb to ./a.out of pid 20236 on display
>>>> [n12-76:20232] 3 more processes have sent help message
>>>> help-mpi-runtime.txt / mpi_init:warn-fork
>>>> [n12-76:20232] Set MCA parameter "orte_base_help_aggregate" to 0 to see
>>>> all help / error messages
>>>>     1
>>>> [1]PETSC ERROR: ------------------------------
>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> probably memory access out of range
>>>> [1]PETSC ERROR: Try option -start_in_debugger or
>>>> -on_error_attach_debugger
>>>> [1]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSCERROR: or try
>>>> http://valgrind.org
>>>>     on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>> [1]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>>>> and run
>>>> [1]PETSC ERROR: to get more information on the crash.
>>>> [1]PETSC ERROR: User provided function() line 0 in unknown directory
>>>> unknown file (null)
>>>> [3]PETSC ERROR: ------------------------------
>>>> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> [3]PETSC ERROR: Try option -start_in_debugger or
>>>> [3]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[3]PETSCERROR: or try
>>>> http://valgrind.org
>>>> [3]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>>>> and run
>>>> [3]PETSC ERROR: to get more information on the crash.
>>>> [3]PETSC ERROR: User provided function() line 0 in unknown directory
>>>> unknown file (null)
>>>> Thank you.
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> On 14/4/2014 9:05 PM, Barry Smith wrote:
>>>>      Because IO doesn’t always get flushed immediately it may not be
>>>> hanging at this point.  It is better to use the option -start_in_debugger
>>>> then type cont in each debugger window and then when you think it is
>>>> “hanging” do a control C in each debugger window and type where to see
>>>> where each process is you can also look around in the debugger at variables
>>>> to see why it is “hanging” at that point.
>>>>       Barry
>>>>      This routines don’t have any parallel communication in them so are
>>>> unlikely to hang.
>>>> On Apr 14, 2014, at 6:52 AM, TAY wee-beng
>>>>     wrote:
>>>> Hi,
>>>> My code hangs and I added in mpi_barrier and print to catch the bug. I
>>>> found that it hangs after printing "7". Is it because I'm doing something
>>>> wrong? I need to access the u,v,w array so I use DMDAVecGetArrayF90. After
>>>> access, I use DMDAVecRestoreArrayF90.
>>>>            call MPI_Barrier(MPI_COMM_WORLD,ierr);  if (myid==0) print
>>>> *,"3"
>>>> *,"4"
>>>> *,"5"
>>>>            call I_IIB_uv_initial_1st_dm(I_cell_no_u1,I_cell_no_v1,I_
>>>> cell_no_w1,I_cell_u1,I_cell_v1,I_cell_w1,u_array,v_array,w_array)
>>>> *,"6"
>>>>  !must be in reverse order
>>>> *,"7"
>>>> *,"8"
>>>> Thank you.
>>>> Yours sincerely,
>>>> TAY wee-beng
>>>> <code.txt>
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140519/39572b8a/attachment-0001.html>
