[petsc-users] Differences between jacobi and bjacobi preconditioner for cg method 1-processor/block
Jonathan Wong jon.the.wong at gmail.com
Mon May 19 03:57:16 CDT 2014
I'm running into an issue for a symmetric (may not be pd) finite element
problem where I am using the cg method and getting an indefinite_mat or
indefinite_pc error using the jacobi preconditioner. If I change the pc
type to bjacobi, it converges nicely. I am only using 1 process, and I
assumed they would produce the same result, as I'm using default options.
Does anyone have any ideas why this would happen?
It also works fine with gmres + jacobi pc.
Jon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140519/17f707e5/attachment.html>
