[petsc-users] Problem with DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
TAY wee-beng zonexo at gmail.com
Sun May 18 22:28:13 CDT 2014
On 19/5/2014 9:53 AM, Matthew Knepley wrote:
> On Sun, May 18, 2014 at 8:18 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi Barry,
>     I am trying to sort out the details so that it's easier to
>     pinpoint the error. However, I tried on gnu gfortran and it worked
>     well. On intel ifort, it stopped at one of the
>     "DMDAVecGetArrayF90". Does it definitely mean that it's a bug in
>     ifort? Do you work with both intel and gnu?
> Yes it works with Intel. Is this using optimization?
Hi Matt,
I forgot to add that in non-optimized cases, it works with gnu and
intel. However, in optimized cases, it works with gnu, but not intel.
Does it definitely mean that it's a bug in ifort?
>   Matt
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
>     On 14/5/2014 12:03 AM, Barry Smith wrote:
>            Please send you current code. So we may compile and run it.
>            Barry
>            On May 12, 2014, at 9:52 PM, TAY wee-beng <zonexo at gmail.com
>             Hi,
>             I have sent the entire code a while ago. Is there any
>             answer? I was also trying myself but it worked for some
>             intel compiler, and some not. I'm still not able to find
>             the answer. gnu compilers for most cluster are old
>             versions so they are not able to compile since I have
>             allocatable structures.
>             Thank you.
>             Yours sincerely,
>             TAY wee-beng
>             On 21/4/2014 8:58 AM, Barry Smith wrote:
>                     Please send the entire code. If we can run it and
>                 reproduce the problem we can likely track down the
>                 issue much faster than through endless rounds of email.
>                     Barry
>                 On Apr 20, 2014, at 7:49 PM, TAY wee-beng
>                 <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>                     On 20/4/2014 8:39 AM, TAY wee-beng wrote:
>                         On 20/4/2014 1:02 AM, Matthew Knepley wrote:
>                             On Sat, Apr 19, 2014 at 10:49 AM, TAY
>                             On 19/4/2014 11:39 PM, Matthew Knepley wrote:
>                                 On Sat, Apr 19, 2014 at 10:16 AM, TAY
>                                 On 19/4/2014 10:55 PM, Matthew Knepley
>                                 wrote:
>                                     On Sat, Apr 19, 2014 at 9:14 AM,
>                                     On 19/4/2014 6:48 PM, Matthew
>                                     Knepley wrote:
>                                         On Sat, Apr 19, 2014 at 4:59
>                                         AM, TAY wee-beng
>                                         On 19/4/2014 1:17 PM, Barry
>                                         Smith wrote:
>                                         On Apr 19, 2014, at 12:11 AM,
>                                         On 19/4/2014 12:10 PM, Barry
>                                         Smith wrote:
>                                         On Apr 18, 2014, at 9:57 PM,
>                                         On 19/4/2014 3:53 AM, Barry
>                                         Smith wrote:
>                                             Hmm,
>                                                 Interface
>                                         DMDAVecGetArrayF90
>                                                   Subroutine
>                                         DMDAVecGetArrayF903(da1,
>                                         v,d1,ierr)
>                                                     USE_DM_HIDE
>                                                     DM_HIDE da1
>                                                     VEC_HIDE v
>                                         PetscScalar,pointer :: d1(:,:,:)
>                                                     PetscErrorCode ierr
>                                                   End Subroutine
>                                              So the d1 is a F90
>                                         POINTER. But your subroutine
>                                         seems to be treating it as a
>                                         “plain old Fortran array”?
>                                         real(8), intent(inout) ::
>                                         u(:,:,:),v(:,:,:),w(:,:,:)
>                                         Hi,
>                                         So d1 is a pointer, and it's
>                                         different if I declare it as
>                                         "plain old Fortran array"?
>                                         Because I declare it as a
>                                         Fortran array and it works w/o
>                                         any problem if I only call
>                                         DMDAVecRestoreArrayF90 with "u".
>                                         But if I call
>                                         "u", "v" and "w", error starts
>                                         to happen. I wonder why...
>                                         Also, supposed I call:
>                                         call
>                                         DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>                                              call
>                                         DMDAVecGetArrayF90(da_v,v_local,v_array,ierr)
>                                              call
>                                         DMDAVecGetArrayF90(da_w,w_local,w_array,ierr)
>                                         u_array ....
>                                         v_array .... etc
>                                         Now to restore the array, does
>                                         it matter the sequence they
>                                         are restored?
>                                              No it should not matter.
>                                         If it matters that is a sign
>                                         that memory has been written
>                                         to incorrectly earlier in the
>                                         code.
>                                         Hi,
>                                         Hmm, I have been getting
>                                         different results on different
>                                         intel compilers. I'm not sure
>                                         if MPI played a part but I'm
>                                         only using a single processor.
>                                         In the debug mode, things run
>                                         without problem. In optimized
>                                         mode, in some cases, the code
>                                         aborts even doing simple
>                                         initialization:
>                                         call
>                                              call
>                                              call
>                                              call
>                                         DMDAVecGetArrayF90(da_p,p_local,p_array,ierr)
>                                              u_array = 0.d0
>                                              v_array = 0.d0
>                                              w_array = 0.d0
>                                              p_array = 0.d0
>                                              call
>                                         DMDAVecRestoreArrayF90(da_p,p_local,p_array,ierr)
>                                              call
>                                         DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr)
>                                              call
>                                         DMDAVecRestoreArrayF90(da_v,v_local,v_array,ierr)
>                                              call
>                                         DMDAVecRestoreArrayF90(da_u,u_local,u_array,ierr)
>                                         The code aborts at call
>                                         DMDAVecRestoreArrayF90(da_w,w_local,w_array,ierr),
>                                         giving segmentation error. But
>                                         other         version of intel
>                                         compiler passes thru this part
>                                         w/o error. Since the response
>                                         is different among different
>                                         compilers, is this PETSc or
>                                         intel 's bug? Or mvapich or
>                                         openmpi?
>                                         We do this is a bunch of
>                                         examples. Can you reproduce
>                                         this different behavior in
>                                         src/dm/examples/tutorials/ex11f90.F?
>                                     Hi Matt,
>                                     Do you mean putting the above
>                                     lines into ex11f90.F and test?
>                                     It already has DMDAVecGetArray().
>                                     Just run it.
>                                 Hi,
>                                 It worked. The differences between
>                                 mine and the code is the way the
>                                 fortran modules are defined, and the
>                                 ex11f90 only uses global vectors. Does
>                                 it make a difference whether global or
>                                 local vectors are used? Because the
>                                 way it accesses x1 only touches the
>                                 local region.
>                                 No the global/local difference should
>                                 not matter.
>                                   Also, before using
>                                 DMDAVecGetArrayF90, DMGetGlobalVector
>                                 must be used 1st, is that so? I can't
>                                 find the equivalent for local vector
>                                 though.
>                                 DMGetLocalVector()
>                             Ops, I do not have DMGetLocalVector and
>                             DMRestoreLocalVector in my code. Does it
>                             matter?
>                             If so, when should I call them?
>                             You just need a local vector from somewhere.
>                     Hi,
>                     Anyone can help with the questions below? Still
>                     trying to find why my code doesn't work.
>                     Thanks.
>                         Hi,
>                         I insert part of my error region code into
>                         ex11f90:
>                         call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>                                   call
>                                   call
>                                   call
>                              u_array = 0.d0
>                                   v_array = 0.d0
>                                   w_array = 0.d0
>                                   p_array = 0.d0
>                              call
>                              call
>                              call
>                              call
>                         It worked w/o error. I'm going to change the
>                         way the modules are defined in my code.
>                         My code contains a main program and a number
>                         of modules files, with subroutines inside e.g.
>                         module solve
>                                           <- add include file?
>                         subroutine RRK
>                         end subroutine RRK
>                         end module solve
>                         So where should the include files (#include
>                         <finclude/petscdmda.h90>) be placed?
>                         After the module or inside the subroutine?
>                         Thanks.
>                                Matt
>                               Thanks.
>                                     Matt
>                                   Thanks.
>                                         Matt
>                                       Thanks
>                                     Regards.
>                                             Matt
>                                           As in w, then v and u?
>                                         call
>                                         call
>                                         call
>                                         thanks
>                                              Note also that the
>                                         beginning and end indices of
>                                         the u,v,w, are different for
>                                         each process see for example
>                                         http://www.mcs.anl.gov/petsc/petsc-3.4/src/dm/examples/tutorials/ex11f90.F
>                                          (and they do not start at 1).
>                                         This is how to get the loop
>                                         bounds.
>                                         Hi,
>                                         In my case, I fixed the u,v,w
>                                         such that their indices are
>                                         the same. I also checked using
>                                         DMDAGetCorners and
>                                         DMDAGetGhostCorners. Now the
>                                         problem lies in my subroutine
>                                         treating it as a “plain old
>                                         Fortran array”.
>                                         If I declare them as pointers,
>                                         their indices follow the C 0
>                                         start convention, is that so?
>                                              Not really. It is that in
>                                         each process you need to
>                                         access them from the indices
>                                         indicated by DMDAGetCorners()
>                                         for global vectors and
>                                         DMDAGetGhostCorners() for
>                                         local vectors.  So really C or
>                                         Fortran   doesn’t make any
>                                         difference.
>                                         So my problem now is that in
>                                         my old MPI code, the u(i,j,k)
>                                         follow the Fortran 1 start
>                                         convention. Is there some way
>                                         to manipulate such that I do
>                                         not have to change my u(i,j,k)
>                                         to u(i-1,j-1,k-1)?
>                                             If you code wishes to
>                                         access them with indices plus
>                                         one from the values returned
>                                         by DMDAGetCorners() for global
>                                         vectors and
>                                         local vectors then you need to
>                                         manually subtract off the 1.
>                                             Barry
>                                         Thanks.
>                                             Barry
>                                         On Apr 18, 2014, at 10:58 AM,
>                                         Hi,
>                                         I tried to pinpoint the
>                                         problem. I reduced my job size
>                                         and hence I can run on 1
>                                         processor. Tried using
>                                         valgrind but perhaps I'm using
>                                         the optimized version, it
>                                         didn't catch the error,
>                                         besides saying "Segmentation
>                                         fault (core dumped)"
>                                         However, by re-writing my
>                                         code, I found out a few things:
>                                         1. if I write my code this way:
>                                         call
>                                         call
>                                         call
>                                         u_array = ....
>                                         v_array = ....
>                                         w_array = ....
>                                         call
>                                         call
>                                         call
>                                         The code runs fine.
>                                         2. if I write my code this way:
>                                         call
>                                         call
>                                         call
>                                         call
>                                         uvw_array_change(u_array,v_array,w_array)
>                                         -> this subroutine does the
>                                         same modification as the above.
>                                         call
>                                         call
>                                         call
>                                         -> error
>                                         where the subroutine is:
>                                         subroutine uvw_array_change(u,v,w)
>                                         u ...
>                                         v...
>                                         w ...
>                                         end subroutine uvw_array_change.
>                                         The above will give an error at :
>                                         call
>                                         3. Same as above, except I
>                                         change the order of the last 3
>                                         lines to:
>                                         call
>                                         call
>                                         call
>                                         So they are now in reversed
>                                         order. Now it works.
>                                         4. Same as 2 or 3, except the
>                                         subroutine is changed to :
>                                         u(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>                                         v(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>                                         w(start_indices(1):end_indices(1),start_indices(2):end_indices(2),start_indices(3):end_indices(3))
>                                         u ...
>                                         v...
>                                         w ...
>                                         The start_indices and
>                                         end_indices are simply to
>                                         shift the 0 indices of C
>                                         convention to that of the 1
>                                         indices of the Fortran
>                                         convention. This is necessary
>                                         in my case because most of my
>                                         codes start array counting at
>                                         1, hence the "trick".
>                                         However, now no matter which
>                                         order of the
>                                         DMDAVecRestoreArrayF90 (as in
>                                         2 or 3), error will occur at
>                                         "call
>                                         So did I violate and cause
>                                         memory corruption due to the
>                                         trick above? But I can't think
>                                         of any way other       than
>                                         the "trick" to continue using
>                                         the 1 indices convention.
>                                         Thank you.
>                                         Yours sincerely,
>                                         TAY wee-beng
>                                         On 15/4/2014 8:00 PM, Barry
>                                         Smith wrote:
>                                             Try running under valgrind
>                                         http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>                                         On Apr 14, 2014, at 9:47 PM,
>                                         Hi Barry,
>                                         As I mentioned earlier, the
>                                         code works fine in PETSc debug
>                                         mode but fails in non-debug mode.
>                                         I have attached my code.
>                                         Thank you
>                                         Yours sincerely,
>                                         TAY wee-beng
>                                         On 15/4/2014 2:26 AM, Barry
>                                         Smith wrote:
>                                             Please send the code that
>                                         creates da_w and the
>                                         declarations of w_array
>                                             Barry
>                                         On Apr 14, 2014, at 9:40 AM,
>                                         TAY wee-beng
>                                            wrote:
>                                         Hi Barry,
>                                         I'm not too sure how to do it.
>                                         I'm running mpi. So I run:
>                                            mpirun -n 4 ./a.out
>                                         -start_in_debugger
>                                         I got the msg below. Before
>                                         the gdb windows appear (thru
>                                         x11), the program aborts.
>                                         Also I tried running in
>                                         another cluster and it worked.
>                                         Also tried in the current
>                                         cluster in debug mode and it
>                                         worked too.
>                                         mpirun -n 4 ./a.out
>                                         -start_in_debugger
>                                         An MPI process has executed an
>                                         operation involving a call to the
>                                         "fork()" system call to create
>                                         a child process.  Open MPI is
>                                         currently
>                                         operating in a condition that
>                                         could result in memory
>                                         corruption or
>                                         other system errors; your MPI
>                                         job may hang, crash, or
>                                         produce silent
>                                         data corruption.  The use of
>                                         fork() (or system() or other
>                                         calls that
>                                         create child processes) is
>                                         strongly discouraged.
>                                         The process that invoked fork was:
>                                             Local host:
>                                          n12-76 (PID 20235)
>                                             MPI_COMM_WORLD rank: 2
>                                         If you are *absolutely sure*
>                                         that your application will
>                                         successfully
>                                         and correctly survive a call
>                                         to fork(), you may disable
>                                         this warning
>                                         by setting the
>                                         mpi_warn_on_fork MCA parameter
>                                         to 0.
>                                         [2]PETSC ERROR: PETSC:
>                                         Attaching gdb to ./a.out of
>                                         pid 20235 on display
>                                         localhost:50.0 on machine n12-76
>                                         [0]PETSC ERROR: PETSC:
>                                         pid 20233 on display
>                                         [1]PETSC ERROR: PETSC:
>                                         pid 20234 on display
>                                         [3]PETSC ERROR: PETSC:
>                                         pid 20236 on display
>                                         [n12-76:20232] 3 more
>                                         processes have sent help
>                                         message help-mpi-runtime.txt /
>                                         mpi_init:warn-fork
>                                         [n12-76:20232] Set MCA
>                                         parameter
>                                         "orte_base_help_aggregate" to
>                                         0 to see all help / error messages
>                                            1
>                                         [1]PETSC ERROR:
>                                         [1]PETSC ERROR: Caught signal
>                                         number 11 SEGV: Segmentation
>                                         Violation, probably memory
>                                         access out of range
>                                         [1]PETSC ERROR: Try option
>                                         -start_in_debugger or
>                                         -on_error_attach_debugger
>                                         [1]PETSC ERROR: or see
>                                         http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC
>                                         ERROR: or try http://valgrind.org
>                                            on GNU/linux and Apple Mac
>                                         OS X to find memory corruption
>                                         errors
>                                         [1]PETSC ERROR: configure
>                                         using --with-debugging=yes,
>                                         recompile, link, and run
>                                         [1]PETSC ERROR: to get more
>                                         information on the crash.
>                                         [1]PETSC ERROR: User provided
>                                         function() line 0 in unknown
>                                         directory unknown file (null)
>                                         [3]PETSC ERROR:
>                                         [3]PETSC ERROR: Caught signal
>                                         access out of range
>                                         [3]PETSC ERROR: Try option
>                                         [3]PETSC ERROR: or see
>                                         http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[3]PETSC
>                                         errors
>                                         [3]PETSC ERROR: configure
>                                         [3]PETSC ERROR: to get more
>                                         [3]PETSC ERROR: User provided
>                                         Thank you.
>                                         Yours sincerely,
>                                         TAY wee-beng
>                                         On 14/4/2014 9:05 PM, Barry
>                                         Smith wrote:
>                                             Because IO doesn’t always
>                                         get flushed immediately it may
>                                         not be hanging at this point.
>                                          It is better to use the
>                                         option -start_in_debugger then
>                                         type cont in each debugger
>                                         window and then when you think
>                                         it is “hanging” do a control C
>                                         in each debugger window and
>                                         type where to see where each
>                                         process is you can also look
>                                         around in the debugger at
>                                         variables to see why it is
>                                         “hanging” at that point.
>                                              Barry
>                                             This routines don’t have
>                                         any parallel communication in
>                                         them so are unlikely to hang.
>                                         On Apr 14, 2014, at 6:52 AM,
>                                         TAY wee-beng
>                                            wrote:
>                                         Hi,
>                                         My code hangs and I added in
>                                         mpi_barrier and print to catch
>                                         the bug. I found that it hangs
>                                         after printing "7". Is it
>                                         because I'm doing something
>                                         wrong? I need to access the
>                                         u,v,w array so I use
>                                         DMDAVecGetArrayF90. After
>                                         access, I use
>                                         DMDAVecRestoreArrayF90.
>                                                   call
>                                                   call
>                                         MPI_Barrier(MPI_COMM_WORLD,ierr);
>                                          if (myid==0) print *,"3"
>                                                   call
>                                                   call
>                                          if (myid==0) print *,"4"
>                                                   call
>                                                   call
>                                          if (myid==0) print *,"5"
>                                                   call
>                                         I_IIB_uv_initial_1st_dm(I_cell_no_u1,I_cell_no_v1,I_cell_no_w1,I_cell_u1,I_cell_v1,I_cell_w1,u_array,v_array,w_array)
>                                                   call
>                                          if (myid==0) print *,"6"
>                                                   call
>                                          !must be in reverse order
>                                                   call
>                                          if (myid==0) print *,"7"
>                                                   call
>                                                   call
>                                          if (myid==0) print *,"8"
>                                                   call
>                                         Thank you.
>                                         Yours sincerely,
>                                         TAY wee-beng
>                                         <code.txt>
>                                         What most experimenters take
>                                         for granted before they begin
>                                         their experiments is
>                                         infinitely more interesting
>                                         than any results to which
>                                         their experiments lead.
>                                         -- Norbert Wiener
>                                     What most experimenters take for
>                                     granted before they begin their
>                                     experiments is infinitely more
>                                     interesting than any results to
>                                     which their experiments lead.
>                                     -- Norbert Wiener
>                                 interesting than any results to which
>                                 -- Norbert Wiener
>                             What most experimenters take for granted
>                             before they begin their experiments is
>                             infinitely more interesting than any
>                             results to which their experiments lead.
>                             -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140519/fc209428/attachment-0001.html>
