[petsc-users] PetscMalloc with Fortran
Jonas Mairhofer mairhofer at itt.uni-stuttgart.de
Fri May 16 02:59:58 CDT 2014
I tried to use ISColoringValue, but when I include
IScoloringValue   colors
into my code, I get an error message from the compiler(gfortran):
      ISColoringValue colors
       1
     error: unclassifiable statement at (1)
I'm including these header files, am I missing one?
#include <finclude/petscsys.h>
#include <finclude/petscvec.h>
#include <finclude/petscdmda.h>
#include <finclude/petscis.h>
#include <finclude/petscmat.h>
#include <finclude/petscksp.h>
#include <finclude/petscpc.h>
#include <finclude/petscsnes.h>
#include <finclude/petscvec.h90>
#include <finclude/petscdmda.h90>
Thank you for your fast responses!
Am 15.05.2014 19:16, schrieb Peter Brune:
> You should be using an array of type ISColoringValue. ISColoringValue
> is by default a short, not an int, so you're getting nonsense entries.
>  We should either maintain or remove ex5s if it does something like this.
> - Peter
> On Thu, May 15, 2014 at 11:56 AM, Jonas Mairhofer
> <mairhofer at itt.uni-stuttgart.de
> <mailto:mairhofer at itt.uni-stuttgart.de>> wrote:
>     If 'colors' can be a dynamically allocated array then I dont know
>     where
>     the mistake is in this code:
>            ISColoring iscoloring
>            Integer, allocatable :: colors(:)
>            PetscInt maxc
>           !calculate max. number of colors
>           maxc = 2*irc+1 !irc is the number of ghost nodes needed to
>     calculate the function I want to solve
>          allocate(colors(user%xm))  !where user%xm is the number of
>     locally
>     owned nodes of a global array
>          !Set colors
>          DO i=1,user%xm
>               colors(i) = mod(i,maxc)
>          END DO
>         call
>     ISColoringCreate(PETSC_COMM_WORLD,maxc,user%xm,colors,iscoloring,ierr)
>         deallocate(colors)
>         call ISColoringDestroy(iscoloring,ierr)
>     On execution I get the following error message (running the DO
>     Loop from
>     0 to user%xm-1 does not change anything):
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Arguments are incompatible!
>     [0]PETSC ERROR: Number of colors passed in 291 is less then the actual
>     number of colors in array 61665!
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: Petsc Release Version 3.4.4, Mar, 13, 2014
>     [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>     [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>     [0]PETSC ERROR: See docs/index.html for manual pages.
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: ./DFT on a arch-linux2-c-debug named
>     aries.itt.uni-stuttgart.de <http://aries.itt.uni-stuttgart.de> by
>     mhofer Thu May 15 18:01:41 2014
>     [0]PETSC ERROR: Libraries linked from
>     /usr/ITT/mhofer/Documents/Diss/NumericalMethods/Libraries/Petsc/petsc-3.4.4/arch-linux2-c-debug/lib
>     [0]PETSC ERROR: Configure run at Wed Mar 19 11:00:35 2014
>     [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
>     --download-f-blas-lapack --download-mpich
>     [0]PETSC ERROR:
>     [0]PETSC ERROR: ISColoringCreate() line 276 in
>     /usr/ITT/mhofer/Documents/Diss/NumericalMethods/Libraries/Petsc/petsc-3.4.4/src/vec/is/is/utils/iscoloring.c
>     But when I print out colors, it only has entries from 0 to 218, so no
>     entry is larger then 291 as stated in the error message.
>     Am 15.05.2014 16:45, schrieb Jed Brown:
>         Jonas Mairhofer <mairhofer at itt.uni-stuttgart.de
>         <mailto:mairhofer at itt.uni-stuttgart.de>> writes:
>             Hi, I'm trying to set the coloring of a matrix using
>             ISColoringCreate.
>             Therefore I need an array 'colors' which in C can be
>             creates as (from
>             example ex5s.c)
>             int *colors
>             PetscMalloc(...,&colors)
>         There is no PetscMalloc in Fortran, due to language
>         "deficiencies".
>             colors(i) = ....
>             ISColoringCreate(...)
>             How do I have to define the array colors in Fortran?
>             I tried:
>             Integer, allocatable :: colors(:)    and  allocate()
>             instead of
>             PetscMalloc
>             and
>             Integer, pointer :: colors
>             but neither worked.
>         The ISColoringCreate Fortran binding copies from the array you
>         pass into
>         one allocated using PetscMalloc.  You should pass a normal
>         Fortran array
>         (statically or dynamically allocated).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140516/d5793199/attachment.html>
