[petsc-users] MatMPIAIJSetPreallocationCSR
Oliver Browne oliver.browne at upm.es
Wed May 14 07:42:58 CDT 2014
I am using MatMPIAIJSetPreallocationCSR to preallocate the rows, columns
and values for my matrix (efficiency). I have my 3 vectors in CSR
format. If I run on a single processor, with my test case, everything
works fine. I also worked without MatMPIAIJSetPreallocationCSR, and
individually input each value with the call MatSetValues in MPI and this
also works fine.
If I want to use MatMPIAIJSetPreallocationCSR, do I need to separate the
vectors for each processor as they have done here;
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMPIAIJSetPreallocationCSR.html#MatMPIAIJSetPreallocationCSR
Thanks in advance,
Ollie
