[petsc-users] Non-matching KSP and SNES norms during SNES solve
Tue May 13 20:27:38 CDT 2014
On Tue, May 13, 2014 at 7:55 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    What do you mean by ‘''the default “coloring” method’’’
>    If you are using DMDA and either DMGetColoring or the SNESSetDM
> approach and dof is 4 then we color each of the 4 variables per grid point
> with a different color so coupling between variables within a grid point is
> not a problem. This would not explain the problem you are seeing below.
>    Run your code with -snes_type test and read the results and follow the
> directions to debug your Jacobian.
I think there may actually be a bug with the coloring for unstructured
grids. I am distilling it down to a nice test case.
  Matt
>    Barry
> On May 13, 2014, at 1:20 PM, Jean-Arthur Louis Olive <jaolive at MIT.EDU>
> wrote:
> > Hi all,
> > we are using PETSc to solve the steady state Stokes equations with
> non-linear viscosities using finite difference. Recently we have realized
> that our true residual norm after the last KSP solve did not match next
> SNES function norm when solving the linear Stokes equations.
> > So to understand this better, we set up two extremely simple linear
> residuals, one with no coupling between variables (vx, vy, P and T), the
> other with one coupling term (shown below).
> > RESIDUAL 1 (NO COUPLING):
> >   for (j=info->ys; j<info->ys+info->ym; j++) {
> >     for (i=info->xs; i<info->xs+info->xm; i++) {
> >       f[j][i].P = x[j][i].P - 3000000;
> >       f[j][i].vx= 2*x[j][i].vx;
> >       f[j][i].vy= 3*x[j][i].vy - 2;
> >       f[j][i].T = x[j][i].T;
> > RESIDUAL 2 (ONE COUPLING TERM):
> >       f[j][i].P = x[j][i].P - 3;
> >       f[j][i].vx= x[j][i].vx - 3*x[j][i].vy;
> >       f[j][i].vy= x[j][i].vy - 2;
> > and our default set of options is:
> > OPTIONS:  mpiexec -np $np ../Stokes -snes_max_it 4 -ksp_atol 2.0e+2
> -ksp_max_it 20 -ksp_rtol 9.0e-1 -ksp_type fgmres -snes_monitor
> -snes_converged_reason -snes_view -log_summary -options_left 1
> -ksp_monitor_true_residual -pc_type none -snes_linesearch_type cp
> > With the uncoupled residual (Residual 1), we get matching KSP and SNES
> norm, highlighted below:
> > Result from Solve - RESIDUAL 1
> >   0 SNES Function norm 8.485281374240e+07
> >     0 KSP unpreconditioned resid norm 8.485281374240e+07 true resid norm
> 8.485281374240e+07 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP unpreconditioned resid norm 1.131370849896e+02 true resid norm
> 1.131370849896e+02 ||r(i)||/||b|| 1.333333333330e-06
> >   1 SNES Function norm 1.131370849896e+02
> >     0 KSP unpreconditioned resid norm 1.131370849896e+02 true resid norm
> 1.131370849896e+02 ||r(i)||/||b|| 1.000000000000e+00
> >   2 SNES Function norm 1.131370849896e+02
> > Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 2
> > With the coupled residual (Residual 2), the norms do not match, see below
> > Result from Solve - RESIDUAL 2:
> >   0 SNES Function norm 1.019803902719e+02
> >     0 KSP unpreconditioned resid norm 1.019803902719e+02 true resid norm
> 1.019803902719e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP unpreconditioned resid norm 8.741176309016e+01 true resid norm
> 8.741176309016e+01 ||r(i)||/||b|| 8.571428571429e-01
> >   1 SNES Function norm 1.697056274848e+02
> >     0 KSP unpreconditioned resid norm 1.697056274848e+02 true resid norm
> 1.697056274848e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP unpreconditioned resid norm 5.828670868165e-12 true resid norm
> 5.777940247956e-12 ||r(i)||/||b|| 3.404683942184e-14
> >   2 SNES Function norm 3.236770473841e-07
> > Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 2
> > Lastly, if we add -snes_fd to our options, the norms for residual 2 get
> better - they match after the first iteration but not after the second.
> > Result from Solve with -snes_fd - RESIDUAL 2
> >     1 KSP unpreconditioned resid norm 2.039607805429e+02 true resid norm
> 2.039607805429e+02 ||r(i)||/||b|| 2.403700850300e-06
> >   1 SNES Function norm 2.039607805429e+02
> >     0 KSP unpreconditioned resid norm 2.039607805429e+02 true resid norm
> 2.039607805429e+02 ||r(i)||/||b|| 1.000000000000e+00
> >     1 KSP unpreconditioned resid norm 2.529822128436e+01 true resid norm
> 2.529822128436e+01 ||r(i)||/||b|| 1.240347346045e-01
> >   2 SNES Function norm 2.549509757105e+01 [SLIGHTLY DIFFERENT]
> >     0 KSP unpreconditioned resid norm 2.549509757105e+01 true resid norm
> 2.549509757105e+01 ||r(i)||/||b|| 1.000000000000e+00
> >   3 SNES Function norm 2.549509757105e+01
> > Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 3
> > Does this mean that our Jacobian is not approximated properly by the
> default “coloring” method when it has off-diagonal terms?
> > Thanks a lot,
> > Arthur and Eric
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140513/dafaef98/attachment.html>
