[petsc-users] PetscLayoutCreate for Fortran
Tue May 13 20:06:39 CDT 2014
On May 13, 2014, at 11:42 AM, Hossein Talebi <talebi.hossein at gmail.com> wrote:
> I have already decomposed the Finite Element system using Metis. I just need to have the global rows exactly like how I define and I like to have the answer in the same layout so I don't have to move things around the processes again.
   Metis tells you a good partitioning IT DOES NOT MOVE the elements to form a good partitioning. Do you move the elements around based on what metis told you and similarly do you renumber the elements (and vertices) to be contiquously numbered on each process with the first process getting the first set of numbers, the second process the second set of numbers etc?
   If you do all that then when you create Vec and Mat you should simply set the local size (based on the number of local vertices on each process). You never need to use PetscLayoutCreate and in fact if your code was in C you would never use PetscLayoutCreate()
   If you do not do all that then you need to do that first before you start calling PETSc.
   Barry
> No, I don't need it for something else.
> Cheers
> Hossein
> On Tue, May 13, 2014 at 6:36 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 13, 2014 at 11:07 AM, Hossein Talebi <talebi.hossein at gmail.com> wrote:
> Hi All,
> I am using PETSC from Fortran. I would like to define my own layout i.e. which row belongs to which CPU since I have already done the domain decomposition.  It appears that  "PetscLayoutCreate" and the other routine do this. But in the manual it says it is not provided in Fortran.
> Is there any way that I can do this using Fortran? Anyone has an example?
> You can do this for Vec and Mat directly. Do you want it for something else?
>   Thanks,
>      Matt
> Cheers
> Hossein
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> www.permix.org
