[petsc-users] Assembling a matrix for a DMComposite vector
Anush Krishnan anush at bu.edu
Fri May 2 11:36:25 CDT 2014
On 1 May 2014 18:25, Anton Popov <popov at uni-mainz.de> wrote:
>  On 5/1/14 10:39 PM, Anush Krishnan wrote:
> Hi Anton,
> On 29 April 2014 05:14, Anton Popov <popov at uni-mainz.de> wrote:
>>  You can do the whole thing much easier (to my opinion).
>> Since you created two DMDA anyway, just do:
>> - find first index on every processor using MPI_Scan
>> - create two global vectors (no ghosts)
>> - put proper global indicies to global vectors
>> - create two local vectors (with ghosts) and set ALL entries to -1 (to
>> have what you need in boundary ghosts)
>> - call global-to-local scatter
>> Done!
>  Won't the vectors contain floating point values? Are you storing your
> indices as real numbers?
> YES, exactly. And then I cast them to PetscInt when I compose stencils.
> Something like this:
>         idx[0] = (PetscInt) ivx[k][j][i];
>         idx[1] = (PetscInt) ivx[k][j][i+1];
>         idx[2] = (PetscInt) ivy[k][j][i];
>     ... and so on, where ivx, ivy, ... are the index arrays in x, y ..
> directions
> Then I insert (actually add) stencils using MatSetValues.
> By the way, you can ideally preallocate in parallel with
> MatMPIAIJSetPreallocation. To count precisely number entries in the
> diagonal & off-diagonal blocks use the same mechanism to easily access
> global indices, and then compare them with the local row range, which is
> also known:
> - within the range   -> d_nnz[i]++;
> - outside the range -> o_nnz[i]++;
Thanks a lot for the help. I did exactly that and it worked perfectly.
But just to clarify: if I was using 32-bit floats, would I start having
trouble when my matrix size reaches ~10 million due to the floating point
precision?
> Anton
>> The advantage is that you can access global indices (including ghosts) in
>> every block using i-j-k indexing scheme.
>> I personally find this way quite easy to implement with PETSc
>> Anton
>  Thank you,
> Anush
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140502/97175eb9/attachment.html>
