[petsc-users] questions about the SNES Function Norm
Xiangdong epscodes at gmail.com
Thu May 1 10:32:44 CDT 2014
Under what condition, SNESGetFunctionNorm() will output different results
from SENEGetFunction + VecNorm (with NORM_2)?
For most of my test cases, it is the same. However, when I have some
special (trivial) initial guess to the SNES problem, I see different norms.
Another phenomenon I noticed with this is that KSP in SNES squeeze my
matrix by eliminating rows. I have a Jacobian supposed to be 50-by-50. When
I use KSPGetOperators/rhs/solutions, I found that the operator is 25-by-25,
and the rhs and solution is with length 25. Do you have any clue on what
triggered this? To my surprise, when I output the Jacobian inside the
FormJacobianLocal, it outputs the correct matrix 50-by-50 with correct
numerical entries. Why does the operator obtained from KSP is different and
got rows eliminated? These rows got eliminated have only one entries per
row, but the rhs in that row is not zero. Eliminating these rows would give
wrong solutions.
Thank you.
Xiangdong
On Tue, Apr 29, 2014 at 3:12 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Apr 29, 2014 at 2:09 PM, Xiangdong <epscodes at gmail.com> wrote:
>> It turns out to a be a bug  in my FormFunctionLocal(DMDALocalInfo
>> *info,PetscScalar **x,PetscScalar **f,AppCtx *user). I forgot to initialize
>> the array f. Zero the array f solved the problem and gave consistent result.
>> Just curious, why does not petsc initialize the array f to zero by
>> default inside petsc when passing the f array to FormFunctionLocal?
> If you directly set entires, you might not want us to spend the time
> writing those zeros.
>> I have another quick question about the array x passed to
>> FormFunctionLocal. If I want to know the which x is evaluated, how can I
>> output x in a vector format? Currently, I created a global vector vecx and
>> a local vector vecx_local, get the array of vecx_local_array, copy the x to
>> vecx_local_array,  scatter to global vecx and output vecx. Is there a quick
>> way to restore the array x to a vector and output?
> I cannot think of a better way than that.
>    Matt
>> Thank you.
>> Best,
>> Xiangdong
>> On Mon, Apr 28, 2014 at 10:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Apr 28, 2014, at 3:23 PM, Xiangdong <epscodes at gmail.com> wrote:
>>> > Hello everyone,
>>> > When I run snes program,
>>>                ^^^^ what SNES program”?
>>> > it outputs "SNES Function norm 1.23456789e+10". It seems that this
>>> norm is different from residue norm (even if solving F(x)=0)
>>>    Please send the full output where you see this.
>>> > and also differ from norm of the Jacobian. What is the definition of
>>> this "SNES Function Norm”?
>>>    The SNES Function Norm as printed by PETSc is suppose to the 2-norm
>>> of F(x) - b (where b is usually zero) and this is also the same thing as
>>> the “residue norm”
>>>    Barry
>>> > Thank you.
>>> > Best,
>>> > Xiangdong
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140501/081fd5ea/attachment.html>
