[petsc-users] mumps running out of memory, depending on an overall numerical factor?
David Liu daveliu at mit.edu
Fri Jan 31 16:53:53 CST 2014
Hi, I'm solving a 3d problem with mumps. When I increased the grid size to
70x60x20 with 6 unknowns per point, I started noticing that the program was
crashing at runtime at the factoring stage, with the mumps error code:
-17 The internal send buffer that was allocated dynamically by MUMPS on the
processor is too small.
The user should increase the value of ICNTL(14) before calling MUMPS again.
However, when I increase the grid spacing in the z direction by about 50%,
this crash does not happen.
Why would how much memory an LU factorization uses depend on an overall
numerical factor (for part of the matrix at least) like this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140131/1d319829/attachment.html>
