[petsc-users] Setting up a PETSc section for field-split
Thu Jan 30 09:05:56 CST 2014
On Thu, Jan 30, 2014 at 8:36 AM, Luc Berger-Vergiat <lb2653 at columbia.edu>wrote:
>  Thank you so much this helps a lot with my research. I hope that you can
> reuse that little example code for some documentation on DMShell. The
> features available thru that object are really good, it is just a little
> hard (at least for me) to work around all the functions call to set it up.
> For instance I understand that the DM can be used in the KSP to work on
> the Kmat operator but what is the purpose of the PCSetDM? Using the DM on
> the preconditioner operator passed to the KSP?
KSPSetDM() calls PCSetDM() internally. All the solver objects use the DM
for sizes of Vec/Mat objects, and also
for dividing up the problem.
     Matt
> Thanks again for your help, I will try to transfer this to FORTRAN!
> Cheers!
> Best,
> Luc
> On 01/30/2014 08:52 AM, Matthew Knepley wrote:
>  On Wed, Jan 29, 2014 at 7:19 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>wrote:
>>  Hi Matt,
>> I thought I would spend the time writing a small c example of what I am
>> doing in my FORTRAN code so that you can more easily see what it is I am
>> doing wrong.
>> I attached the code and its makefile. I run the code the following
>> arguments:
>> -ksp_type gmres -pc_type fieldsplit -fieldsplit_0_pc_type ilu
>> -fieldsplit_0_ksp_type preonly -fieldsplit_1_pc_type jacobi
>> -fieldsplit_1_ksp_type preonly -ksp_view -ksp_monitor
>  1) You need to also call PetscSectionSetDof() in order to get full
> sizes. I don't just add up the fields.
>  2) You need to set the DM into the KSP using KSPSetDM()
>  3) You need to make the DM inactive if you want to provide your own
> Mat/Vec using KSPSetDMActive()
>  4) Then you can get rid of the special code for FS
>  5) Your options were wrong because you named the fields
>  I include a revised code sample, and you should run with
>    -ksp_type gmres -pc_type fieldsplit -fieldsplit_Field_0_pc_type ilu
> -fieldsplit_Field_0_ksp_type preonly -fieldsplit_Field_1_pc_type jacobi
> -fieldsplit_Field_1_ksp_type preonly -ksp_view -ksp_monitor
>   Thanks,
>       Matt
>   and get the following output:
>> start=1, End=9.
>> PetscSection with 2 fields
>>   field 0 with 1 components
>> Process 0:
>>   (   1) dim  1 offset   0
>>   (   2) dim  1 offset   0
>>   (   3) dim  1 offset   0
>>   (   4) dim  1 offset   0
>>   (   5) dim  0 offset   0
>>   (   6) dim  0 offset   0
>>   (   7) dim  0 offset   0
>>   (   8) dim  0 offset   0
>>   field 1 with 1 components
>> Process 0:
>>   (   1) dim  0 offset   1
>>   (   2) dim  0 offset   1
>>   (   3) dim  0 offset   1
>>   (   4) dim  0 offset   1
>>   (   5) dim  1 offset   0
>>   (   6) dim  1 offset   0
>>   (   7) dim  1 offset   0
>>   (   8) dim  1 offset   0
>> PC flag for GetDMSplits: true
>>   0 KSP Residual norm 0.000000000000e+00
>> KSP Object: 1 MPI processes
>>   type: gmres
>>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>     GMRES: happy breakdown tolerance 1e-30
>>   maximum iterations=10000, initial guess is zero
>>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>   left preconditioning
>>   using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>>   type: fieldsplit
>>     FieldSplit with MULTIPLICATIVE composition: total splits = 2
>>     Solver info for each split is in the following KSP objects:
>>     Split number 0 Defined by IS
>>     KSP Object:    (fieldsplit_Field_0_)     1 MPI processes
>>       type: preonly
>>       using NONE norm type for convergence test
>>     PC Object:    (fieldsplit_Field_0_)     1 MPI processes
>>       type: ilu
>>         ILU: out-of-place factorization
>>         0 levels of fill
>>         tolerance for zero pivot 2.22045e-14
>>         using diagonal shift on blocks to prevent zero pivot
>>         matrix ordering: natural
>>         factor fill ratio given 1, needed 1
>>           Factored matrix follows:
>>             Matrix Object:             1 MPI processes
>>               type: seqaij
>>               rows=0, cols=0
>>               package used to perform factorization: petsc
>>               total: nonzeros=0, allocated nonzeros=0
>>               total number of mallocs used during MatSetValues calls =0
>>                 not using I-node routines
>>       linear system matrix = precond matrix:
>>         type: seqaij
>>         rows=0, cols=0
>>     Split number 1 Defined by IS
>>     KSP Object:    (fieldsplit_Field_1_)     1 MPI processes
>>       type: preonly
>>     PC Object:    (fieldsplit_Field_1_)     1 MPI processes
>>       type: ilu
>>         0 levels of fill
>>               type: seqaij
>>               rows=0, cols=0
>>         type: seqaij
>>         rows=0, cols=0
>>     type: seqaij
>>     rows=8, cols=8
>>     total: nonzeros=64, allocated nonzeros=160
>>     total number of mallocs used during MatSetValues calls =8
>>       using I-node routines: found 2 nodes, limit used is 5
>> The solution to this problem is:
>> Vector Object: 1 MPI processes
>>   type: seq
>> 0
>> 0
>> 0
>> 0
>> 0
>> 0
>> 0
>> 0
>> WARNING! There are options you set that were not used!
>> WARNING! could be spelling mistake, etc!
>> Option left: name:-fieldsplit_0_ksp_type value: preonly
>> Option left: name:-fieldsplit_0_pc_type value: ilu
>> Option left: name:-fieldsplit_1_ksp_type value: preonly
>> Option left: name:-fieldsplit_1_pc_type value: jacobi
>> when I run it with the more simple arguements:
>> -ksp_type gmres -pc_type jacobi -ksp_view -ksp_monitor
>> I get the following output:
>> start=1, End=9.
>> Process 0:
>>   (   1) dim  1 offset   0
>>   (   2) dim  1 offset   0
>>   (   3) dim  1 offset   0
>>   (   4) dim  1 offset   0
>>   (   5) dim  0 offset   0
>>   (   6) dim  0 offset   0
>>   (   7) dim  0 offset   0
>>   (   8) dim  0 offset   0
>> Process 0:
>>   (   1) dim  0 offset   1
>>   (   2) dim  0 offset   1
>>   (   3) dim  0 offset   1
>>   (   4) dim  0 offset   1
>>   (   5) dim  1 offset   0
>>   (   6) dim  1 offset   0
>>   (   7) dim  1 offset   0
>>   (   8) dim  1 offset   0
>>   0 KSP Residual norm 4.759858191165e+00
>>   1 KSP Residual norm 2.344421567248e+00
>>   2 KSP Residual norm 3.208390394507e-01
>>   3 KSP Residual norm 7.171256210359e-02
>>   4 KSP Residual norm 1.301032901980e-02
>>   5 KSP Residual norm 1.104121978197e-15
>>   type: gmres
>>   type: jacobi
>>     type: seqaij
>>     rows=8, cols=8
>>   type: seq
>> -0.977778
>> -0.0444444
>> -0.844444
>> -0.327778
>> 3
>> 1
>> 1.5
>> 3
>> It is obvious that something goes wrong in the fieldsplit, I'm just
>> clueless to what it is. I think that everything is setup correctly but I'm
>> missing something to get the KSP to recognize my splits...
>> Thanks for your help.
>> Best,
>> Luc
>> On 01/28/2014 11:20 AM, Matthew Knepley wrote:
>>  On Tue, Jan 28, 2014 at 10:11 AM, Luc Berger-Vergiat <
>> lb2653 at columbia.edu> wrote:
>>>  What I don't really understand is why the size of all the sub fields
>>> is zero?
>>> As you can see all the matrix object in my fieldsplit preconditioner
>>> have total:nonzeros=0, allocated nonzeros=0.
>>> This seems strange since I issued the following command:
>>>      call DMSetDefaultSection(FSDM, FSSection, ierr)
>>  That section looks like you never called PetscSectionSetUp().
>>     Matt
>>>  with a the following FSSection:
>>> PetscSection with 4 fields
>>> Process 0:
>>>   (   0) dim  0 offset   0
>>>   (   1) dim  1 offset   0
>>>   (   2) dim  0 offset   0
>>>   (   3) dim  0 offset   0
>>>   (   4) dim  1 offset   0
>>>   (   5) dim  0 offset   0
>>>   (   6) dim  0 offset   0
>>>   (   7) dim  0 offset   0
>>>   (   8) dim  0 offset   0
>>>   (   9) dim  0 offset   0
>>>   (  10) dim  0 offset   0
>>>   (  11) dim  0 offset   0
>>>   (  12) dim  0 offset   0
>>>   (  13) dim  0 offset   0
>>>   (  14) dim  0 offset   0
>>>   (  15) dim  0 offset   0
>>> Process 0:
>>>   (   0) dim  1 offset   0
>>>   (   1) dim  0 offset   1
>>>   (   2) dim  1 offset   0
>>>   (   3) dim  1 offset   0
>>>   (   4) dim  0 offset   1
>>>   (   5) dim  1 offset   0
>>>   (   6) dim  0 offset   0
>>>   (   7) dim  0 offset   0
>>>   (   8) dim  0 offset   0
>>>   (   9) dim  0 offset   0
>>>   field 2 with 1 components
>>> Process 0:
>>>   (   0) dim  0 offset   1
>>>   (   1) dim  0 offset   1
>>>   (   2) dim  0 offset   1
>>>   (   3) dim  0 offset   1
>>>   (   4) dim  0 offset   1
>>>   (   5) dim  0 offset   1
>>>   (   6) dim  1 offset   0
>>>   (   7) dim  1 offset   0
>>>   (   8) dim  1 offset   0
>>>   (   9) dim  1 offset   0
>>>   (  10) dim  1 offset   0
>>>   (  11) dim  1 offset   0
>>>   field 3 with 1 components
>>> Process 0:
>>>   (   0) dim  0 offset   1
>>>   (   1) dim  0 offset   1
>>>   (   2) dim  0 offset   1
>>>   (   3) dim  0 offset   1
>>>   (   4) dim  0 offset   1
>>>   (   5) dim  0 offset   1
>>>   (   6) dim  0 offset   1
>>>   (   7) dim  0 offset   1
>>>   (   8) dim  0 offset   1
>>>   (   9) dim  0 offset   1
>>>   (  10) dim  0 offset   1
>>>   (  11) dim  0 offset   1
>>>   (  12) dim  1 offset   0
>>>   (  13) dim  1 offset   0
>>>   (  14) dim  1 offset   0
>>>   (  15) dim  1 offset   0
>>> I thought that by using DMSetDefaultSection() I would be done setting
>>> the fields and that the fieldsplit would detect that section and use it to
>>> construct the splits.
>>> Should I use another command to tell the PC to use the DM section?
>>> Best,
>>> Luc
>>> On 01/28/2014 10:25 AM, Matthew Knepley wrote:
>>>  On Mon, Jan 27, 2014 at 1:35 PM, Luc Berger-Vergiat <
>>>>  Thanks Matt,
>>>> this indeed setting the number of fields earlier solve my issue!
>>>> I have now made some progress getting my DM setup but I am having
>>>> troubles setting my splitfield options.
>>>> I ran my problem with the -ksp_view option to see what is going on and
>>>> I guess that somehow the section that I define in my DM is not used by the
>>>> preconditioner to split the fields.
>>>> Here is the output of PETSc
>>>>   type: gmres
>>>>   tolerances:  relative=1e-08, absolute=1e-16, divergence=1e+16
>>>>   type: fieldsplit
>>>>     FieldSplit with MULTIPLICATIVE composition: total splits = 4
>>>  There are 4 splits here and they are defined by an IS. Why do you
>>> think that is not what you asked for?
>>>    Thanks,
>>>      Matt
>>>>       type: preonly
>>>>       type: ilu
>>>>         0 levels of fill
>>>>               type: seqaij
>>>>               rows=0, cols=0
>>>>         type: seqaij
>>>>         rows=0, cols=0
>>>>       type: preonly
>>>>       type: ilu
>>>>         0 levels of fill
>>>>               type: seqaij
>>>>               rows=0, cols=0
>>>>         type: seqaij
>>>>         rows=0, cols=0
>>>>     Split number 2 Defined by IS
>>>>     KSP Object:    (fieldsplit_Field_2_)     1 MPI processes
>>>>       type: preonly
>>>>     PC Object:    (fieldsplit_Field_2_)     1 MPI processes
>>>>       type: ilu
>>>>         0 levels of fill
>>>>               type: seqaij
>>>>               rows=0, cols=0
>>>>         type: seqaij
>>>>         rows=0, cols=0
>>>>     Split number 3 Defined by IS
>>>>     KSP Object:    (fieldsplit_Field_3_)     1 MPI processes
>>>>       type: preonly
>>>>     PC Object:    (fieldsplit_Field_3_)     1 MPI processes
>>>>       type: ilu
>>>>         0 levels of fill
>>>>               type: seqaij
>>>>               rows=0, cols=0
>>>>         type: seqaij
>>>>         rows=0, cols=0
>>>>     type: seqaij
>>>>     rows=16, cols=16
>>>>     total: nonzeros=256, allocated nonzeros=256
>>>>       using I-node routines: found 4 nodes, limit used is 5
>>>> I am also attaching part of my code which I use to generate the DM, the
>>>> KSP and the PC objects.
>>>> Best,
>>>> Luc
>>>> On 01/25/2014 10:31 AM, Matthew Knepley wrote:
>>>>  On Fri, Jan 24, 2014 at 5:10 PM, Luc Berger-Vergiat <
>>>>> Hi all,
>>>>> I want to use PETSc as a solver for an FEM problem: modelization of
>>>>> shear bands using a 4 fields mixed formulation.
>>>>> So far I am just trying to set up a two fields in a Petsc section,
>>>>> assign dof too each field and then set up the section to pass it to a DM. I
>>>>> am taking this approach because in general I want for fieldsplit to work
>>>>> purely on the algebraic level without knowledge of boundary conditions or
>>>>> geometry.
>>>>> As of now I have issues when I try to assign a point and its
>>>>> associated degree of freedom to a field using: PetscSectionSetFieldDof.
>>>>> Is this the correct way to associate a dof/point to a field?
>>>>  You have to set the number of fields before the chart. I am updating
>>>> the docs.
>>>>   Thanks,
>>>>      Matt
>>>>> I attached an example code and its makefile.
>>>>> Best,
>>>>> Luc
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140130/aac82946/attachment-0001.html>
