[petsc-users] Setting up a PETSc section for field-split
Thu Jan 30 07:52:28 CST 2014
On Wed, Jan 29, 2014 at 7:19 PM, Luc Berger-Vergiat <lb2653 at columbia.edu>wrote:
>  Hi Matt,
> I thought I would spend the time writing a small c example of what I am
> doing in my FORTRAN code so that you can more easily see what it is I am
> doing wrong.
> I attached the code and its makefile. I run the code the following
> arguments:
> -ksp_type gmres -pc_type fieldsplit -fieldsplit_0_pc_type ilu
> -fieldsplit_0_ksp_type preonly -fieldsplit_1_pc_type jacobi
> -fieldsplit_1_ksp_type preonly -ksp_view -ksp_monitor
1) You need to also call PetscSectionSetDof() in order to get full sizes. I
don't just add up the fields.
2) You need to set the DM into the KSP using KSPSetDM()
3) You need to make the DM inactive if you want to provide your own Mat/Vec
using KSPSetDMActive()
4) Then you can get rid of the special code for FS
5) Your options were wrong because you named the fields
I include a revised code sample, and you should run with
  -ksp_type gmres -pc_type fieldsplit -fieldsplit_Field_0_pc_type ilu
-fieldsplit_Field_0_ksp_type preonly -fieldsplit_Field_1_pc_type jacobi
-fieldsplit_Field_1_ksp_type preonly -ksp_view -ksp_monitor
     Matt
and get the following output:
> start=1, End=9.
> PetscSection with 2 fields
>   field 0 with 1 components
> Process 0:
>   (   1) dim  1 offset   0
>   (   2) dim  1 offset   0
>   (   3) dim  1 offset   0
>   (   4) dim  1 offset   0
>   (   5) dim  0 offset   0
>   (   6) dim  0 offset   0
>   (   7) dim  0 offset   0
>   (   8) dim  0 offset   0
>   field 1 with 1 components
> Process 0:
>   (   1) dim  0 offset   1
>   (   2) dim  0 offset   1
>   (   3) dim  0 offset   1
>   (   4) dim  0 offset   1
>   (   5) dim  1 offset   0
>   (   6) dim  1 offset   0
>   (   7) dim  1 offset   0
>   (   8) dim  1 offset   0
> PC flag for GetDMSplits: true
>   0 KSP Residual norm 0.000000000000e+00
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with MULTIPLICATIVE composition: total splits = 2
>     Solver info for each split is in the following KSP objects:
>     Split number 0 Defined by IS
>     KSP Object:    (fieldsplit_Field_0_)     1 MPI processes
>       type: preonly
>       using NONE norm type for convergence test
>     PC Object:    (fieldsplit_Field_0_)     1 MPI processes
>       type: ilu
>         ILU: out-of-place factorization
>         0 levels of fill
>         tolerance for zero pivot 2.22045e-14
>         using diagonal shift on blocks to prevent zero pivot
>         matrix ordering: natural
>         factor fill ratio given 1, needed 1
>           Factored matrix follows:
>             Matrix Object:             1 MPI processes
>               type: seqaij
>               rows=0, cols=0
>               package used to perform factorization: petsc
>               total: nonzeros=0, allocated nonzeros=0
>               total number of mallocs used during MatSetValues calls =0
>                 not using I-node routines
>       linear system matrix = precond matrix:
>         type: seqaij
>         rows=0, cols=0
>     Split number 1 Defined by IS
>     KSP Object:    (fieldsplit_Field_1_)     1 MPI processes
>       type: preonly
>     PC Object:    (fieldsplit_Field_1_)     1 MPI processes
>       type: ilu
>         0 levels of fill
>               type: seqaij
>               rows=0, cols=0
>         type: seqaij
>         rows=0, cols=0
>     type: seqaij
>     rows=8, cols=8
>     total: nonzeros=64, allocated nonzeros=160
>     total number of mallocs used during MatSetValues calls =8
>       using I-node routines: found 2 nodes, limit used is 5
> The solution to this problem is:
> Vector Object: 1 MPI processes
>   type: seq
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> 0
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-fieldsplit_0_ksp_type value: preonly
> Option left: name:-fieldsplit_0_pc_type value: ilu
> Option left: name:-fieldsplit_1_ksp_type value: preonly
> Option left: name:-fieldsplit_1_pc_type value: jacobi
> when I run it with the more simple arguements:
> -ksp_type gmres -pc_type jacobi -ksp_view -ksp_monitor
> I get the following output:
> start=1, End=9.
> Process 0:
>   (   1) dim  1 offset   0
>   (   2) dim  1 offset   0
>   (   3) dim  1 offset   0
>   (   4) dim  1 offset   0
>   (   5) dim  0 offset   0
>   (   6) dim  0 offset   0
>   (   7) dim  0 offset   0
>   (   8) dim  0 offset   0
> Process 0:
>   (   1) dim  0 offset   1
>   (   2) dim  0 offset   1
>   (   3) dim  0 offset   1
>   (   4) dim  0 offset   1
>   (   5) dim  1 offset   0
>   (   6) dim  1 offset   0
>   (   7) dim  1 offset   0
>   (   8) dim  1 offset   0
>   0 KSP Residual norm 4.759858191165e+00
>   1 KSP Residual norm 2.344421567248e+00
>   2 KSP Residual norm 3.208390394507e-01
>   3 KSP Residual norm 7.171256210359e-02
>   4 KSP Residual norm 1.301032901980e-02
>   5 KSP Residual norm 1.104121978197e-15
>   type: gmres
>   type: jacobi
>     type: seqaij
>     rows=8, cols=8
>   type: seq
> -0.977778
> -0.0444444
> -0.844444
> -0.327778
> 3
> 1
> 1.5
> 3
> It is obvious that something goes wrong in the fieldsplit, I'm just
> clueless to what it is. I think that everything is setup correctly but I'm
> missing something to get the KSP to recognize my splits...
> Thanks for your help.
> Best,
> Luc
> On 01/28/2014 11:20 AM, Matthew Knepley wrote:
>  On Tue, Jan 28, 2014 at 10:11 AM, Luc Berger-Vergiat <lb2653 at columbia.edu
> > wrote:
>>  What I don't really understand is why the size of all the sub fields is
>> zero?
>> As you can see all the matrix object in my fieldsplit preconditioner have
>> total:nonzeros=0, allocated nonzeros=0.
>> This seems strange since I issued the following command:
>>      call DMSetDefaultSection(FSDM, FSSection, ierr)
>  That section looks like you never called PetscSectionSetUp().
>     Matt
>>  with a the following FSSection:
>> PetscSection with 4 fields
>> Process 0:
>>   (   0) dim  0 offset   0
>>   (   1) dim  1 offset   0
>>   (   2) dim  0 offset   0
>>   (   3) dim  0 offset   0
>>   (   4) dim  1 offset   0
>>   (   5) dim  0 offset   0
>>   (   6) dim  0 offset   0
>>   (   7) dim  0 offset   0
>>   (   8) dim  0 offset   0
>>   (   9) dim  0 offset   0
>>   (  10) dim  0 offset   0
>>   (  11) dim  0 offset   0
>>   (  12) dim  0 offset   0
>>   (  13) dim  0 offset   0
>>   (  14) dim  0 offset   0
>>   (  15) dim  0 offset   0
>> Process 0:
>>   (   0) dim  1 offset   0
>>   (   1) dim  0 offset   1
>>   (   2) dim  1 offset   0
>>   (   3) dim  1 offset   0
>>   (   4) dim  0 offset   1
>>   (   5) dim  1 offset   0
>>   (   6) dim  0 offset   0
>>   (   7) dim  0 offset   0
>>   (   8) dim  0 offset   0
>>   (   9) dim  0 offset   0
>>   field 2 with 1 components
>> Process 0:
>>   (   0) dim  0 offset   1
>>   (   1) dim  0 offset   1
>>   (   2) dim  0 offset   1
>>   (   3) dim  0 offset   1
>>   (   4) dim  0 offset   1
>>   (   5) dim  0 offset   1
>>   (   6) dim  1 offset   0
>>   (   7) dim  1 offset   0
>>   (   8) dim  1 offset   0
>>   (   9) dim  1 offset   0
>>   (  10) dim  1 offset   0
>>   (  11) dim  1 offset   0
>>   field 3 with 1 components
>> Process 0:
>>   (   0) dim  0 offset   1
>>   (   1) dim  0 offset   1
>>   (   2) dim  0 offset   1
>>   (   3) dim  0 offset   1
>>   (   4) dim  0 offset   1
>>   (   5) dim  0 offset   1
>>   (   6) dim  0 offset   1
>>   (   7) dim  0 offset   1
>>   (   8) dim  0 offset   1
>>   (   9) dim  0 offset   1
>>   (  10) dim  0 offset   1
>>   (  11) dim  0 offset   1
>>   (  12) dim  1 offset   0
>>   (  13) dim  1 offset   0
>>   (  14) dim  1 offset   0
>>   (  15) dim  1 offset   0
>> I thought that by using DMSetDefaultSection() I would be done setting the
>> fields and that the fieldsplit would detect that section and use it to
>> construct the splits.
>> Should I use another command to tell the PC to use the DM section?
>> Best,
>> Luc
>> On 01/28/2014 10:25 AM, Matthew Knepley wrote:
>>  On Mon, Jan 27, 2014 at 1:35 PM, Luc Berger-Vergiat <lb2653 at columbia.edu
>> > wrote:
>>>  Thanks Matt,
>>> this indeed setting the number of fields earlier solve my issue!
>>> I have now made some progress getting my DM setup but I am having
>>> troubles setting my splitfield options.
>>> I ran my problem with the -ksp_view option to see what is going on and I
>>> guess that somehow the section that I define in my DM is not used by the
>>> preconditioner to split the fields.
>>> Here is the output of PETSc
>>>   type: gmres
>>>   tolerances:  relative=1e-08, absolute=1e-16, divergence=1e+16
>>>   type: fieldsplit
>>>     FieldSplit with MULTIPLICATIVE composition: total splits = 4
>>  There are 4 splits here and they are defined by an IS. Why do you think
>> that is not what you asked for?
>>    Thanks,
>>      Matt
>>>       type: preonly
>>>       type: ilu
>>>         0 levels of fill
>>>               type: seqaij
>>>               rows=0, cols=0
>>>         type: seqaij
>>>         rows=0, cols=0
>>>       type: preonly
>>>       type: ilu
>>>         0 levels of fill
>>>               type: seqaij
>>>               rows=0, cols=0
>>>         type: seqaij
>>>         rows=0, cols=0
>>>     Split number 2 Defined by IS
>>>     KSP Object:    (fieldsplit_Field_2_)     1 MPI processes
>>>       type: preonly
>>>     PC Object:    (fieldsplit_Field_2_)     1 MPI processes
>>>       type: ilu
>>>         0 levels of fill
>>>               type: seqaij
>>>               rows=0, cols=0
>>>         type: seqaij
>>>         rows=0, cols=0
>>>     Split number 3 Defined by IS
>>>     KSP Object:    (fieldsplit_Field_3_)     1 MPI processes
>>>       type: preonly
>>>     PC Object:    (fieldsplit_Field_3_)     1 MPI processes
>>>       type: ilu
>>>         0 levels of fill
>>>               type: seqaij
>>>               rows=0, cols=0
>>>         type: seqaij
>>>         rows=0, cols=0
>>>     type: seqaij
>>>     rows=16, cols=16
>>>     total: nonzeros=256, allocated nonzeros=256
>>>       using I-node routines: found 4 nodes, limit used is 5
>>> I am also attaching part of my code which I use to generate the DM, the
>>> KSP and the PC objects.
>>> Best,
>>> Luc
>>> On 01/25/2014 10:31 AM, Matthew Knepley wrote:
>>>  On Fri, Jan 24, 2014 at 5:10 PM, Luc Berger-Vergiat <
>>> lb2653 at columbia.edu> wrote:
>>>> Hi all,
>>>> I want to use PETSc as a solver for an FEM problem: modelization of
>>>> shear bands using a 4 fields mixed formulation.
>>>> So far I am just trying to set up a two fields in a Petsc section,
>>>> assign dof too each field and then set up the section to pass it to a DM. I
>>>> am taking this approach because in general I want for fieldsplit to work
>>>> purely on the algebraic level without knowledge of boundary conditions or
>>>> geometry.
>>>> As of now I have issues when I try to assign a point and its associated
>>>> degree of freedom to a field using: PetscSectionSetFieldDof.
>>>> Is this the correct way to associate a dof/point to a field?
>>>  You have to set the number of fields before the chart. I am updating
>>> the docs.
>>>   Thanks,
>>>      Matt
>>>> I attached an example code and its makefile.
>>>> Best,
>>>> Luc
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140130/6524d604/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140130/6524d604/attachment-0001.c>
