[petsc-users] Configuration of Hybrid MPI-OpenMP
Jed Brown jed at jedbrown.org
Wed Jan 29 20:08:03 CST 2014
Danyang Su <danyang.su at gmail.com> writes:
> Hi Karli,
> "--with-threadcomm --with-openmp" can work when configure PETSc with
> MPI-OpenMP. Sorry for making a mistake before.
> The program can be compiled but I got a new error while running my program.
> Error: Attempting to use an MPI routine before initializing MPICH
> This error occurs when calling MPI_SCATTERV. I have already called
> PetscInitialize, and MPI_BCAST, which is just before the calling of
> MPI_SCATTERV, can also work without throwing error.
> When PETSc is configured without openmp, there is no error in this section.
Are you calling this inside an omp parallel block?  Are you initializing
MPI with MPI_THREAD_MULTIPLE?  Do you have other threads doing something
with MPI?
I'm afraid we'll need a reproducible test case if it still doesn't work
for you.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140129/92204531/attachment.pgp>
