[petsc-users] reusing LU factorization?
Hong Zhang hzhang at mcs.anl.gov
Wed Jan 29 11:33:57 CST 2014
Tabrez:
>  I am getting the opposite result, i.e., MUMPS becomes slower when using
> ParMETIS for parallel ordering. What did I mess up? Is the problem too
> small?
I saw similar performance when adding parallel symbolic factorization into
petsc interface, thus I did not set
parallel symbolic factorization as default for petsc/mumps interface.
How large is your matrix?
Can you send us output of '-log_summary' for these two runs?
Hong
> Case 1 took 24.731s
> $ rm -f *vtk; time mpiexec -n 16 ./defmod -f point.inp -pc_type lu
> -pc_factor_mat_solver_package mumps -mat_mumps_icntl_4 1 -log_summary >
> 1.txt
> Case 2 with "-mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2" took 34.720s
> -mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2 > 2.txt
> Both 1.txt and 2.txt are attached.
> Regards,
> Tabrez
> On 01/29/2014 09:18 AM, Hong Zhang wrote:
> MUMPS now supports parallel symbolic factorization. With petsc-3.4
> interface, you can use runtime option
>    -mat_mumps_icntl_28 <1>: ICNTL(28): use 1 for sequential analysis and
> ictnl(7) ordering, or 2 for parallel analysis and ictnl(29) ordering
>   -mat_mumps_icntl_29 <0>: ICNTL(29): parallel ordering 1 = ptscotch 2 =
> parmetis
>  e.g, '-mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2' activates parallel
> symbolic factorization with pametis for matrix ordering.
> Give it a try and let us know what you get.
>  Hong
> On Tue, Jan 28, 2014 at 5:48 PM, Smith, Barry F. <bsmith at mcs.anl.gov>wrote:
>> On Jan 28, 2014, at 5:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Tue, Jan 28, 2014 at 5:25 PM, Tabrez Ali <stali at geology.wisc.edu>
>> wrote:
>> > Hello
>> > This is my observation as well (with MUMPS). The first solve (after
>> assembly which is super fast) takes a few mins (for ~1 million unknowns on
>> 12/24 cores) but from then on only a few seconds for each subsequent solve
>> for each time step.
>> > Perhaps symbolic factorization in MUMPS is all serial?
>> > Yes, it is.
>>     I missed this. I was just assuming a PETSc LU. Yes, I have no idea of
>> relative time of symbolic and numeric for those other packages.
>>   Barry
>> >   Matt
>> > Like the OP I often do multiple runs on the same problem but I dont
>> know if MUMPS or any other direct solver can save the symbolic
>> factorization info to a file that perhaps can be utilized in subsequent
>> reruns to avoid the costly "first solves".
>> > Tabrez
>> > On 01/28/2014 04:04 PM, Barry Smith wrote:
>> > On Jan 28, 2014, at 1:36 PM, David Liu<daveliu at mit.edu>  wrote:
>> > Hi, I'm writing an application that solves a sparse matrix many times
>> using Pastix. I notice that the first solves takes a very long time,
>> >    Is it the first "solve" or the first time you put values into that
>> matrix that "takes a long time"? If you are not properly preallocating the
>> matrix then the initial setting of values will be slow and waste memory.
>>  See
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatXAIJSetPreallocation.html
>> >    The symbolic factorization is usually much faster than a numeric
>> factorization so that is not the cause of the slow "first solve".
>> >     Barry
>> > while the subsequent solves are very fast. I don't fully understand
>> what's going on behind the curtains, but I'm guessing it's because the very
>> first solve has to read in the non-zero structure for the LU factorization,
>> while the subsequent solves are faster because the nonzero structure
>> doesn't change.
>> > My question is, is there any way to save the information obtained from
>> the very first solve, so that the next time I run the application, the very
>> first solve can be fast too (provided that I still have the same nonzero
>> structure)?
>> > No one trusts a model except the one who wrote it; Everyone trusts an
>> observation except the one who made it- Harlow Shapley
>> > What most experimenters take for granted before they begin their
>> experiments lead.
>> > -- Norbert Wiener
> No one trusts a model except the one who wrote it; Everyone trusts an observation except the one who made it- Harlow Shapley
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140129/c3bc444c/attachment-0001.html>
